RCK5422BX mower spindle shaft seal, left, right
   / RCK5422BX mower spindle shaft seal, left, right #1
tshep
Richmond, VA
BX23 MLB
As above...
Upper seal has 'stop' flange, so depth is obvious.
Lower seal does not.
(The bearing does have a groove to go past, to show depth for lower bearing.)
So, does lower seal go in:
far enough to 'touch' bearing, or
just flush to shaft housing,
or anywhere in between.
I went with deep to bearing, as shaft has a bit of protrusion 'into' shaft housing area.
I can still feel the shaft engage seal surface as it goes in.
Anyone familiar?
   / RCK5422BX mower spindle shaft seal, left, right #2
Anyone familiar?
I don’t quite understand the sentence that I’ve highlighted in blue.
I replaced the bearings on an outside spindle on my 60 inch version of the same deck. I believe I just put the seals flush with the housing surface. You do want the seal orientation such that excess grease that is pumped in comes out the bottom seal (blade end). I believe my deck is a RCK60-22BX. It is on my BX2200.
Trying to say:
A visual quick check showed the shaft flange could not go flush to housing with a perfectly flush seal, there was a radius (filet?) between shaft and flange, and then a bit of shaft that was not machined down as much as the seal area. So, the seal needed to be, at least, a bit down in the housing, but I have no guidance as to how far.
I did find others' Youtube stuff with recessed seals, so I do not feel too bad about mine
   / RCK5422BX mower spindle shaft seal, left, right #4
I think I just put mine flush, but don’t remember for sure. Unfortunately I did not take any pictures and it’s been a while.
Edit: The parts manual I have for my deck is for a RCK60B-22BX
   / RCK5422BX mower spindle shaft seal, left, right #5
Here is the page from the mower deck Workshop manual which covers both of our decks.
2003 Ford Excursion 4x4 (MPV), VIN # 1FMSU43PX3EC07978 (A51572)
2003 Ford...
2017 VOLVO VNL SLEEPER (A52577)
2017 VOLVO VNL...
MCELROY 500 SERIES 3 TRACSTAR FUSION MACHINE (A52472)
MCELROY 500 SERIES...
CHANDLER 20FT 16 TON HYDRAULIC SPREADER (A52472)
CHANDLER 20FT 16...
2019 JOHN DEERE 5090M LOT NUMBER 91 (A53084)
2019 JOHN DEERE...
2012 SULLIVAN PALATEK AIR COMPRESSOR (A52576)
2012 SULLIVAN...
