RCK54 odd ball failure
   / RCK54 odd ball failure #1
tshep
Richmond, VA
BX23 MLB
Rebuilding a RCK54-15BX, but would be common to same design.
The tension arm uses a clip to keep the tension pulley up and off of the arm itself.
On my wife's mower, string got under the clip, wound up tight in the groove, and lifted the clip out of its groove on the shaft, but stayed on the shaft.
The pulley 'fell', pushed the clip down the shaft, and the pulley followed it on down.
The pulley rode on the tension arm long enough to cut about 1/3 way through, and cooked paint for 2 inches.
If you see your tension pulley has touched the tension arm, I would be suspicious of the same thing.
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2018 F150 (A56436)
2018 F150 (A56436)
2008 V.E. ENTERPRISES 130BBL VAC TRAILER (A58214)
2008 V.E...
2021 KOMATSU WA200-8 WHEEL LOADER (A60429)
2021 KOMATSU...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
