Mowing rck54-22bx tension spring
   / rck54-22bx tension spring #1
parkwatydog
Murrysville, pa
Kubota bx22
I recently had to repair one of the mower blades on my rck54-22bx deck. I am really struggling to restore the tension pulley and the tension spring as pulling the spring with the belt in place seems to require the strength of a super-hero. Am I missing some trick or some tool or is it just a matter of brute strength? Thanks in advance.
   / rck54-22bx tension spring #2
Oh yeah that's no fun! I did this on my 60" a couple of years back and I tried a bunch of different ideas like putting the spring on with the belt off and using a large pry bar to retract the tension pulley enough to slip the belt on. In the end I seem to recall just using a large screw driver to stretch the spring and catch it in the hole. I remember feeling kind of lucky when it caught after only a few tries. Maybe someone else has worked out a more fool proof method.
Good luck!
Sent from my iPad using TractorByNet
   / rck54-22bx tension spring #3
Hopefully I can articulate this so it is understandable. One of the best tools I have seen for this was a one half inch steel bar approximately three foot long with a T handle on one end. The other end had U approximately two inches long. The short side of the U was bent out to about a thirty degree angle.
The individual could remove or install belts quickly. The U allowed the tool to be positioned in such a way on the retention post to allow the bent side to be twisted forcing the spring from the post, yet retaining control.
   / rck54-22bx tension spring #4
Oh, yeah. Took my spring off for winter storage a few years ago - never again. About got a hernia trying to put it back on. Had me and the wife working on it at one point. I believe I used a combination of a ratchet strap and a come-along. I think the come-along worked in the end. Trying to remember, but I think I used the ratchet strap to secure the deck to an immovable object, then the come along to get the spring on. It was a real b-i-t-c-h.
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A51573)
(1) HD 24ft Free...
2018 INTERNATIONAL LT SLEEPER (A52576)
2018 INTERNATIONAL...
28013 (A50322)
28013 (A50322)
2017 Case IH Magnum 380 ROWTRAC CVT Tractor (A53342)
2017 Case IH...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A53472)
80in HD Tooth...
BESTWAY AG VSK50 LOT NUMBER 105 (A53084)
BESTWAY AG VSK50...
