RCF2072 cutter shroud removal or greasing technique
   / RCF2072 cutter shroud removal or greasing technique #1
Aggie66
Rockdale TX
MX 5400
im needing to grease the rear ujoint on my shredder. The shroud with the hole and side doors doesn’t make it any easier. Also if I want to slip the clutch the side doors are difficult. Has anyone removed the shroud and can explain how to do it. If I could take the rear shaft off I’d do that but I think it’s hard attached. Any experience or suggestions on how you do this or what kind of grease method is welcome. I guess I’m just ignorant of how that shroud was installed. Can’t figure it out. Thanks
   / RCF2072 cutter shroud removal or greasing technique #2
Curious to learn how it can be easier, but I have been able to both grease the u-joint and slip the clutch on this cutter just using the side doors.
I do take the cover off the PTO shaft itself though (there are the three plastic fastners you can rotate 90deg with a flathead screwdriver, pull off, then remove/move the cover for the end of the PTO shaft).
2011 TIGER CHEMISE GOOSENECK (A58216)
2011 TIGER CHEMISE...
2019 Toro Z Master 3000 Series 52in Zero Turn Commercial Mower (A56857)
2019 Toro Z Master...
2013 CHRYSLER 300 Sedan (A56859)
2013 CHRYSLER 300...
2015 Honda Accord Sedan (A56859)
2015 Honda Accord...
John Deere 1025R Sub-Compact Tractor Mower (A56857)
John Deere 1025R...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
