RCF2072 Bush hog blades hitting deck
   / RCF2072 Bush hog blades hitting deck #1
sparky
Nashville, TN
JD 5205
On start up, with engine speed low, the blades are hitting the underside of the deck. Once spinning everything is fine. Damaging the deck! Nothing is loose, blades swing freely. Can't physically get the blade within 3" of the deck manually when shut down. I would not think that they are hitting based on that, but they are! Blades do not appear to be bent but I don't have a new blade to compare to. gear box is not loose.
Thoughts?
   / RCF2072 Bush hog blades hitting deck #2
It seldom happens to a Bush Hog but deck on lower quality cutters often crack allowing deck to flex.
   / RCF2072 Bush hog blades hitting deck #3
If they are truly hitting then something IS bent, broke, and or loose ! A cracked deck around the gear box is what I was thinking if all else is good.
You only need to start one thread on a subject , no need to have multiples.
   / RCF2072 Bush hog blades hitting deck #4
Can you see where the blades are actually hitting the deck? Or are you hearing the chatter of the blades only on startup until they fully swing out?
   / RCF2072 Bush hog blades hitting deck #5
I'm betting the blades are striking the skirt on the back or side. Backing up or going forward, while turning can bend the skirt especially if an object is hit.
Whatever the blades are striking it will be obvious, use a jack stand and get under there and look..
   / RCF2072 Bush hog blades hitting deck #6
Maybe the blades hit each other, if one swings out before the other?
Could blades be on upside down with the offset going up instead of down?
   / RCF2072 Bush hog blades hitting deck #7
^This :thumbsup:
Are blades actually hitting underside (the horizontal decking) or are they hitting the side skirting?
Raising it up and looking under (while using safety stands), it will be obvious where it's hitting by where the shiny metal is.
When you say they don't get within 3", it can be hard to tell if blades are rotated straight out from their connection on stump jumper or if they are slightly angled when you're spinning it by hand .
I have one of these cheap Frontiers, RC2084 7ft version. It is what it is. I've gotten better at not backing into rocks and trees and folding the sides into the blades, but my land has so many banks and ditches that uneven ground can fold the sides in too if one backs and turns the wrong way. Being aware of the problem I've reduce folding the sides in from about from 50% of the time I use it to about 25%.
Most likely the bottom of the skirt is folded in just enough that blades only hit at low rpms when blades "droop" from gravity. I suspect at higher rpms, centrifugal force "raises" the blades more straight out to where they the miss the skirt.
Tricks to straightening skirt can involve some BIG pipe wrenches. I found best method is parking it between two trees. Chain one side of mower frame to tree as an anchor (so you don't twist tractor's 3 point hitch) and use a come-a-long attached on the other side to mower's skirt and the other tree to bend it back. It might not look as pretty as it was before when you're done.
   / RCF2072 Bush hog blades hitting deck #8
Maybe so but wouldn't it be easier to just ask. Besides,crawling beneath there could result in dirt in eyes or worse.:laughing:
   / RCF2072 Bush hog blades hitting deck #9
I've found the spindle nut loose on a couple of cutters. They both had some hard use. That could cause some wobble.
I wouldn't ignore this. You definitely don't want the whole thing dropping off while cutting.:eek:
KUBOTA 80" QUICK ATTACH BUCKET (A51406)
KUBOTA 80" QUICK...
UNUSED FUTURE 16" HYD AUGER (A52706)
UNUSED FUTURE 16"...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2022 Club Car Tempo Cart (A55852)
2022 Club Car...
Pemberton 5460 Loader Root Rake (A56857)
Pemberton 5460...
2015 Ford Transit Cargo Van (A54814)
2015 Ford Transit...
