RC72-30B blade questions
/ RC72-30B blade questions #1
Bigtwin
Bronze Member
South Central,Oklahoma
Kubota B3030, MX5100HST
Anyone know the nut size on the blades for the RC72-30B? The largest socket I have is 1 1/8 and it's too small.
Also, everyone go with the standard Kubota blades when replacing them or is there something better?
I have about 130 hour of mowing time and it seems the blades need sharpened or replaced. Is it difficult to sharpent the blades?
/ RC72-30B blade questions #2
They can be sharpen... I leave mine on the tractor, raise it, block it so it can not fall on you, grind away...
How many rocks have you hit??? That might be a factor to think about... but they should last for years.
I occassionaly hit a little gravel. When I cut some of the areas that I let go for a bit too long, it may take a couple passes to clip is down low (2 1/2 inches) where some of the tall stuff (native grass) was. I assumed the blades may need sharpened or replaced.
Do you know the socket size needed to remove the bolt/nut holding the blades on?
I did find the old part # was 76553-34330 and the new part # is 70000-25002.
/ RC72-30B blade questions #5
I seem to recall this question here before and 30mm was the size.1 3/16" is also close.Typical size for front wheel drive cars-removes the front axle retaining nut before replacing the front wheel bearings(hub assemblies).Good Luck!
2007 International CE200 School Bus (A64194)
2007 International...
2020 CATERPILLAR CS44B SMOOTH DRUM ROLLER (A65053)
2020 CATERPILLAR...
2003 Freightliner FS65 Converted School Bus (A64194)
2003 Freightliner...
2025 SDLanch SDLL60 Mini Stand-On Track Loader Skid Steer (A64553)
2025 SDLanch...
2024 JOHN DEERE TURF GATOR (A63276)
2024 JOHN DEERE...
2019 MULTIQUIP TOWABLE GENERATOR (A63276)
2019 MULTIQUIP...
