RC2048 really smooth
/ RC2048 really smooth #1
RalphVa
Super Member
Charlottesville, VA, USA
JD 2025R, previously Gravely 5650 & JD 4010 & JD 1025R
I removed the blades and "sharpened" them on the Frontier RC2048 bush hog (blades look something like Rocky Marciano's face after a bad fight). The nuts weren't particularly tight when I loosened them with my 6 ft piece of pipe on my 3/4 inch plain handle. I was careful in putting the bolts back to get them into the detents properly after using a file a little bit on the detent recesses. (The bolts have a protrustion that goes into detents that keep them from rotating.) Going back on, the nuts didn't need much movement after snugging with ratchet wrench handle followed with plain handle and 6 ft pipe to get them as tight as I could push (my 420 ft lb, e.g. maybe 70 # applied to my 6 foot pipe).
I always run the thing a bit with the trail wheel off and retorque later. So, I took it down and hit some briar patches. Really smooth this year.
Wondering if I should replace the nuts and lock nuts?
Ralph
/ RC2048 really smooth #2
It sounds like you did everything right. Some recommend replacing the blade bolts with every new blade change. I replace when damaged (part of head chipped off, or the area the blade swings on is worn/grooved)
If meant should you replace the blade nuts WITH locknuts, I see no need.
Unused 2026 Schulte SMR-800 Hydraulic Multi-Rake Skid Steer Attachment (A66734)
Unused 2026...
2016 JAY FLIGHT BY JAYCO BUMPER PULL CAMPER (A67714)
2016 JAY FLIGHT BY...
CAT D6 SU Blade / Arms (A68134)
CAT D6 SU Blade /...
2009 Case CX240B Excavator (A64194)
2009 Case CX240B...
2017 FORD F-150 FOOD TRANSPORT TRUCK (A67714)
2017 FORD F-150...
2018 BRADLEY MACHINE MINI VAC TRAILER (A67714)
2018 BRADLEY...
