rates of snow removel around the country
   / rates of snow removel around the country #1
case245
Platinum Member
pa
kubota 7040sud
i wondering what you guys charge per hour in diffrent part of the country a landscaper want me to work for him i have a kubota 7040su fel 4x4
   / rates of snow removel around the country #2
I am not too sure but using your equipment should bring $50-60 if you are doing it under his name using his insurance . He is probably going to charge around $80-100 I would guess. It will also differ if he is transporting it for you and giving you fuel or not. I could be way off here, I have never done it this way, probably someone that has will give you a better answer.
   / rates of snow removel around the country #3
Here in Northern, VA I was getting $110 per hour for me and my tractor with front end loader and blade. I was sub-contracted on a government contract. When I do residential, however, I drop to $75/ hour or charge a fixed amount depending on the job.
Hawk
i would be have my own insurance i will be hauling the tractor does that make a diffirents
   / rates of snow removel around the country #5
You have to figure your operating costs first. What the tractor per hour burns, insurance, transport time, and any other expenses.. Then your hourly rate on top of that.. Are you using a pusher or just the loader? Cab or out in the elements ? I wont be out in the elements making $60 an hour moving snow I will say that ! Tell him to make an offer and if your happy with it put it in a contract !
i have to move tractor to an from the job pay for diesel fuel gas in the truck i have insureance i pay all my own costs when plowing
   / rates of snow removel around the country #8
i'm still in the $75 an hour camp, whether it's on a trailer or working. A good job with a few hours, maybe only charge one way travel time? I live in an area of a pretty depressed economy, nobody drops a plow unless they can avg $75 an hour, at minimum. If you had 3 or 4 driveways to do in a close area, you should be able to get $100 an hour and provide good service. Line up 4 driveways at $25 a pop, take 45/60 minutes, move on the the next group of driveways?
im subcontracting i was told 65 hr around here but i have not much clue a little your tractor about the size of mine but open staton
   / rates of snow removel around the country #10
Here in Kansas City, our average is $85/hr for a tractor/loader, skid loader etc. Although, when I put my spreader on the back and pull "double duty" I'm able to charge $110/hr not including salt/ice melt.
Residential however, is pretty cheap. Generally $25-$35 for a "normal" urban 40-50 ft driveway. Here in more rural parts, drives start @ $75 and go up from there.
1973 JEEP RENEGADE (A51247)
1973 JEEP RENEGADE...
(APPROX 36) 2" X 5" X 21" CHANNEL IRON (A51247)
(APPROX 36) 2" X...
74in FEL HD Round Back Bucket (A53472)
74in FEL HD Round...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A53472)
80in HD Tooth...
UNUSED AGT SA-FT HYD PALLET FORKS (A51248)
UNUSED AGT SA-FT...
(2) COLUMN PROTECTORS (A51248)
(2) COLUMN...
