Rate of down valve?
   / Rate of down valve? #1
yod67
JD 4200, JD x360, JD z950r JD x739
On my JD 4200 I have repaired the o-ring on rate of down valve 2 times in the last year. Yesterday it happened again. Question is what would be causing the o-ring to let go? In both instance that it let go I was working the 3 pt. hard (lot of up and down motions) with my gill pulverizer. Was wondering if debris is in the hyd. oil and that was chewing up the 0-ring. Any other possibilities that may causing this to happen. As we all know it always breaks down when busy.
Couple of things I'm considering: heat from over use? last two o-ring wasn't john deere parts they were from a local part store? Original o-ring lasted 8 years. debris in the oil? just a couple of thoughts is there any more?
   / Rate of down valve? #3
temperature and proper oring. there are a lot oring materials out there. i would get the oem one. I dont believe even dirty hyd fluid wont hurt it. Do you adjust it alot? that might wear it out sooner
   / Rate of down valve? #4
It's likely that the parts store replacements may be made of a different material and/or have a different Durometer spec than the original.
   / Rate of down valve? #5
I agree...try a JD part and see if it holds up better.
I never adjust the rate of down knob. Just ordered a original one today from John Deere but fix it with a part store one. The last o-ring lasted about 2 weeks. I Needed the machine to work today. Thanks for all the relpies.
   / Rate of down valve? #7
How does the o-ring look when it is removed. Is it chewed up? Maybe there is a burr or debris in the valve that is damaging the o-ring. It may be worth inspecting the area in the valve where the o-ring seats. Also I have had situations where if the o-ring is not exactly the right size it can be damaged on installation.
Just some random thoughts.
Yep o-ring was chewed up on one side. The valve sits in a position that it is hard to look in. After I had the valve out I turned over the engine to flush if any debris out. Valve measures about 1 1/2" x 1/2" round and the o-ring fits in a slot.
   / Rate of down valve? #9
Just to use the correct terminology, it's the "Rate of Drop" valve.
2015 CASE 580N (A47477)
2015 CASE 580N...
ST205/75R15 Trailer Tires (A55787)
ST205/75R15...
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
2012 DOOSAN G25KW GENERATOR (A53843)
2012 DOOSAN G25KW...
2017 Ford F-150 Crew Cab Pickup Truck (A54814)
2017 Ford F-150...
JOHN DEERE XUV590M (A53084)
JOHN DEERE XUV590M...
