Rate of down valve?
   / Rate of down valve? #1
yod67
JD 4200, JD x360, JD z950r JD x739
On my JD 4200 I have repaired the o-ring on rate of down valve 2 times in the last year. Yesterday it happened again. Question is what would be causing the o-ring to let go? In both instance that it let go I was working the 3 pt. hard (lot of up and down motions) with my gill pulverizer. Was wondering if debris is in the hyd. oil and that was chewing up the 0-ring. Any other possibilities that may causing this to happen. As we all know it always breaks down when busy.
Couple of things I'm considering: heat from over use? last two o-ring wasn't john deere parts they were from a local part store? Original o-ring lasted 8 years. debris in the oil? just a couple of thoughts is there any more?
   / Rate of down valve? #3
temperature and proper oring. there are a lot oring materials out there. i would get the oem one. I dont believe even dirty hyd fluid wont hurt it. Do you adjust it alot? that might wear it out sooner
   / Rate of down valve? #4
It's likely that the parts store replacements may be made of a different material and/or have a different Durometer spec than the original.
   / Rate of down valve? #5
I agree...try a JD part and see if it holds up better.
I never adjust the rate of down knob. Just ordered a original one today from John Deere but fix it with a part store one. The last o-ring lasted about 2 weeks. I Needed the machine to work today. Thanks for all the relpies.
   / Rate of down valve? #7
How does the o-ring look when it is removed. Is it chewed up? Maybe there is a burr or debris in the valve that is damaging the o-ring. It may be worth inspecting the area in the valve where the o-ring seats. Also I have had situations where if the o-ring is not exactly the right size it can be damaged on installation.
Just some random thoughts.
Yep o-ring was chewed up on one side. The valve sits in a position that it is hard to look in. After I had the valve out I turned over the engine to flush if any debris out. Valve measures about 1 1/2" x 1/2" round and the o-ring fits in a slot.
   / Rate of down valve? #9
Just to use the correct terminology, it's the "Rate of Drop" valve.
UNUSED SWICT 84" QUICK ATTACH BUCKET (A54757)
UNUSED SWICT 84"...
2012 JOHN DEERE 333D SKID STEER (A52706)
2012 JOHN DEERE...
2015 Eager Beaver 15HBB-PT T/A Flatbed Equipment Trailer (A50322)
2015 Eager Beaver...
HAMM 3205 SMOOTH DRUM ROLLER (A51242)
HAMM 3205 SMOOTH...
2022 Allmond Bros Maxi-Lite II 20kW S/A Towable Light Tower (A52377)
2022 Allmond Bros...
2016 CATERPILLAR 277D SKID STEER (A52705)
2016 CATERPILLAR...
