Ratchet Rake pull-behind
/ Ratchet Rake pull-behind #1
TxMN
North Central Texas
2020 Kubota MX5400 HST, ROPS, 2020 Kubota RTV 900, 2020 Kubota RTV 500(wifeç—´ ride),
I love my ratchet rake, is Anyone using their pull-behind with an RTV .
/ Ratchet Rake pull-behind #3
Mine...
/ Ratchet Rake pull-behind #4
I've had a ratchet rake on my FEL most of the time for years. I have about 90 acres of brushy woodland and the RR is perfect for pushing out brush and piling it up. That's why I bought it. But I then discovered that it was perfect for minor maintenance of my mile-long gravel driveway. It fills in holes and really smooths things out perfectly without having to mount a blade, landscape rake or box blade. Even after heavy maintenance or with new gravel, it is great. Only problem is that, after years of use, the short teeth going down have worn down about 50 percent. They still work but not as well. I had hoped that, as a long time user, I would be able to get a new RR at a low rate, but no deal. So I'll be paying full freight, but not until I absolutely have to. By the way, I have used a few other toothbars and found they are OK but not a brute force as the RR for removing brush - they cut it too often - and of little use on the driveway.
2007 Sterling L8500 Single Axle Day Cab (A62613)
2007 Sterling...
Landhonor HPF-11-3000G, 48" Heavy Duty Forks (A62679)
Landhonor...
New/Unused Landhonor Quick Attach 3 Point Hitch Adapter (A65583)
New/Unused...
New Quick Attach Power Spreader (A65579)
New Quick Attach...
2012 TROXELL 200BBL CRUDE TANKER (A65643)
2012 TROXELL...
Fencing Wire (A62613)
