Ratchet Rake - ever seen/used one?
   / Ratchet Rake - ever seen/used one? #331
Anyone use the 72 inch Ratchet Rake with the Kubota 72 inch HD round back bucket with the bolt on edge?
It looks like a very interesting attachment to me although a touch pricey to try sight unseen at $410.
That's the exact bucket I use with my 72" Ratchet Rake. It works good. I just bought the forest service connectors (you can with that bucket) when one of the cables broke on the strap system. It broke when I was back dragging and caught a low stump. The forest service connectors uses chains instead of cables and straps.
   / Ratchet Rake - ever seen/used one? #332
I love my RR.
Just used it last night to clear out about 60' of steep bank that was covered in trees and brush. Cleaned it right up...
   / Ratchet Rake - ever seen/used one? #333
Good to know the heavier connectors work with the 72 inch HD kubota bucket. I left a question at the RR site and never heard back.
If you had to do it again, would you go for the 72 or the next size down? Also I am thinking of putting on welded chain hooks and want to make sure they don't interfere with the RR strap locations of the 72 inch size.
   / Ratchet Rake - ever seen/used one? #334
On the RR website they have pics/specs on what sizes fit what buckets and the distances between straps, etc.
   / Ratchet Rake - ever seen/used one? #335
I saw that and but I don't have the tractor/bucket yet to measure. I planned to stop by the dealer at some point maybe next week and look at the bucket and measure with the RR in mind. Won't actually have the tractor for up to a couple weeks (they have ordered parts for extra hydraulics) and I wanted to order the RR before that so I can put it to use as soon as possible.
In reading the recent threads, sometimes the RR's are back ordered a few weeks.
Right now considering the 72 RR and torn between the regular and chain model.
   / Ratchet Rake - ever seen/used one? #336
Not sure about the availability of the 72 RR. Got my 68 RR from TSC a couple years ago. If you can get a 72 and it fits your bucket, that would be the way to go. The 72 has 5/8 steel and the others have 1/2.
   / Ratchet Rake - ever seen/used one? #337
I have the 72" HD Kubota bucket with the bolt on edge.
Definitely get the 72" RR and get the forestry connection for a few extra bucks. It will fit you bucket.
I have one hook in the center by the dealers recommendation - and it was a good recommendation.
   / Ratchet Rake - ever seen/used one? #338
Emailed them and both 72's in stock. I ordered the FS 72.
   / Ratchet Rake - ever seen/used one? #339
Don't forget to get your 2 chains so you will be ready to work as soon as it arrives.
(10) 28' Continuous Fencing Panels (A50515)
(10) 28'...
UNUSED JCT SKID STEER QUICK ATTACH TRENCHER (A51244)
UNUSED JCT SKID...
Kinze 2600 16 x 31 Row Planter (A52349)
Kinze 2600 16 x 31...
2015 Mitsubishi Mirage Sedan (A50324)
2015 Mitsubishi...
SET OF 48" QUICK ATTACH MAST PALLET FORKS (A51242)
SET OF 48" QUICK...
2018 Nissan Versa Sedan (A50324)
2018 Nissan Versa...
