Rarer/less-known/different welding rods I have
   / Rarer/less-known/different welding rods I have #1
LD1
Epic Contributor
Central Ohio
Kubota MX5100
Well, not really I have, but have access to at work.
I was cleaning out the welding supplies at work and came across some different rods that I have never heard of. So ofcourse I googled them and did a little reading, but I am more curious as to you guys' experiences with these rods or if you have ever heard of them.
They are the following
Super Missle Rod (red flux)
x-ergon #106 (grey flux)
eutectrode 680 (blue flux)
So...what say you'all about these rods and when/where have you used them? how did you like them?
   / Rarer/less-known/different welding rods I have #2
I have never heard of any of them. Any AWS classificationa and SFA numbers on them
   / Rarer/less-known/different welding rods I have #3
Missle weld is some type of maintenance rod for various metals ( I have some and have only used a couple rods) and is made by Harris if you want to look it up
Nope
Ineresting though, the x-ergon 106 has a MUCH higher tensil and yield strengths than 7018, and not sensitive to moisture, and welds like butter:thumbsup:
One may then ask: why isnt it popular like 7018
Well, the reading I have been able to find is that rods like these I mention are propritary and use some "secret" recipe, and thus without wanting to give that away, these rods arent certified and can not be used for "code" work as a result. Even IF they may be a better and stronger weld.
I did do some fooling around sticking metal together and breaking it, and all 3 above plus 7018 and really wasnt much difference in any of them as far as strength. This was in a simple butt weld with 1/8" gap and 1/4" plate. Welded one side only and then broke in the vice with the hammer bending the weld back over itself(weak direction). Again, not a noticable difference at all in terms of strenght IMO. But of all of them, the super missle weld was probabally the easiest rod to lay. It laid down like a 6013 or 7014 would.
   / Rarer/less-known/different welding rods I have #6
Seems as I remember it being a pain to weld vertical up. But I could be wrong, last time I used any must have been 1988.
That could be. I only did a horizontal flat with it and it was nice.
We dont do much out-of-position welding at work. Everything is usually dont in the shop on the bench where it can be rolled around to get "in-position". And we mostly mig stiff anyway. We rarley use the stick anymore since we modified the mig to be hoisted in the air with a forklift. Cause before that, any high work was stick because the leads on the mig only reached so high. Now the stick is reserved for only old and dirty, or cast.
   / Rarer/less-known/different welding rods I have #8
I have run tons of the Super Missile Weld. We used it for welding cast steel, (not cast iron). It is a high class 312 stainless steel. I'm guessing around $35.00 a pouSuper Missileweld | The Harris Products Group
Supper Missile is in fact a 312 SS with a fancy flux. Heavily priced for the nich market. 120K tensile flows like mercury. We always sold it to weld steel to cast steel or other dis similar metals. I have a bunch I would sell but you can buy Stoody Versalloy for $8.00# and it's the same rod.
That makes it a tougher rod than even the popular 7018. Nice.:thumbsup: And dont have to jump through hoops to store it. I couldnt find the tensile strength on it. But I didnt look hard either:rolleyes:
   / Rarer/less-known/different welding rods I have #10
I used to sell all the Harris products. Some of the more nich or smoke -n - mirrors material was Welco 52, Al-Core and Cor-Al for Aluminum, 14FC,17FC for silver brazing with gaps. All the Ni Rods. 28,55,65,94,99. All fun to sell but they all have 1/2 price equivelants in other brands. I still have tons of this stuff as well as various Silver Solders and fluxes.
UNUSED FUTURE 14' BI-PARTING WROUGHT IRON GATE (A51248)
UNUSED FUTURE 14'...
UNUSED JCT 72" HD BRUSH CUTTER (A51248)
UNUSED JCT 72" HD...
UNSUED WOLVERINE TL-12-72W-72" HYD TILLER (A51248)
UNSUED WOLVERINE...
2025 SDLANCH SDLGC80 UNUSED Electric Golf Cart (A53117)
2025 SDLANCH...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2013 WABASH 53x102 DRY VAN (A53426)
2013 WABASH 53x102...
