Oil & Fuel ran out of fuel
   / ran out of fuel #1
rolandrod
First hello to all I'm new to this site. now my problem, my son was having a great time on our b7100hst that he ran it bone dry i refueled it but now i cannot get it to turn over. It is my first diesel and i am unfamiliar what to do if you run it completly out of fuel. any help will be appreciated.
okay it really was not my boy who ran it dry /forums/images/graemlins/tongue.gif
   / ran out of fuel #2
You need to bleed the fuel system. Your manual should have this procedure explained in detail for you.
   / ran out of fuel #3
Running out of fuel happened twice to my B7100. As has been said, the operator's manual has pretty clear instructions and it's actually pretty quick and simple, but I'm not sure I can describe it adequately without pictures.
First, go to the fuel filter and there is what looks like two bolt heads above the filter (10mm, if I remember right). I believe it's the right one that you just loosen until the filter fills with fuel. Then go to each injector, one at a time, loosen one, hit the starter with the throttle lever pulled all the way back to the "kill" position so it can't start. When you get fuel instead of air and/or bubbles coming from that injector line, re-tighten it and move to the next one and do the same. After doing all three, it'll start just fine.
Now my B7100 HST was a 1995 model, so if yours is different????????
   / ran out of fuel
Thank you very much, i did what you said and it started just fine
*Selling at Royal Auction Zephyrhills, FL Location* (A59228)
*Selling at Royal...
40' CONTAINER (A58376)
UNUSED FUTURE XKH39 39" HYD MINI HYD 4IN1 BUCKET (A58376)
UNUSED FUTURE...
2010 Honda CR-V SUV (A55853)
2010 Honda CR-V...
Swict 66" Bucket (A57149)
Swict 66" Bucket...
(4) 6' GATES & (1) 10' GATE (A58376)
(4) 6' GATES & (1)...
