...ran out of diesel, won't start, how do I...
   / ...ran out of diesel, won't start, how do I... #1
Big Hammer
Bronze Member
My Lil Satoh Buck S470 tractor. K3B diesel, ran out of fuel yesterday. I believe I will need to bleed the fuel line (?) , or crack a fitting (?) , or prime the fuel pump (?)... Problem for me is I am not sure how to do it. Any help / suggestions would be mucho appreciated.
Mark
   / ...ran out of diesel, won't start, how do I... #2
loosen the front screw above the fuel filter till fuel begins to run out, then retighten. Then loosen the big screw at the fuel pump (the one in the hole in mesh side panel) until fuel runs out with no air bubbles, then retighten. That should do it.
   / ...ran out of diesel, won't start, how do I... #3
You may need to crack the lines at the injectors if the above post does not do it.
The 2 times I ran my beaver out, it ran very crappy for a while till it finally cleared out. Did the bleeder at the pump and even at the injectors.
My JD's dont have this problem but that is probably because they have an electric tranfer pump which fills the system up better than gravity feed like these tractors have.
Hey, it worked! thanks for the instructions / suggestions. All I had to do was open the little bleeder @ the fuel pump til I saw fuel pouring out. Also took the opportunity to add a new fuel shut-off (didn't have one before) and replaced the filter. Back to work...
Mark
2000 GAL FUEL TANK (A53843)
2000 GAL FUEL TANK...
2013 Cadillac ATS Sedan (A53424)
2013 Cadillac ATS...
2021 HAMM HD+9I VO SMOOTH DOUBLE DRUM ROLLER (A52706)
2021 HAMM HD+9I VO...
JOHN DEERE 2150 TRACTOR (A51406)
JOHN DEERE 2150...
4 Unused Montreal ST205/75R15 Trailer Tires (A53421)
4 Unused Montreal...
2012 Freightliner Cascadia - Class 8, 6x4, Detroit DD13 (A52748)
2012 Freightliner...
