Ram vs Dodge/Chrysler - how complete is the separation?
   / Ram vs Dodge/Chrysler - how complete is the separation? #171
Mercedes had the 402/403/404/405 series engines from the mid 70s onward. It was a weight optimised naturally aspirated engine family consisting of V6 of 9 liter, V8, 10 up to V12 for special applications. They all shared the 90 degree block angle optimal for the V8
There were later iterations of this engine, 20 years ago a water wagon at a paving firm i worked for at the time, so it must be built 40 years ago. It was the 90 degree V6, they ground the fuel pump helixes so that it idled on 3 cylinders to get even firing intervals at idle. Nonetheless when idling it still hogged like a pig on a cold morning. I think the last iteration of the V6 had offset crank pins because the engine was so rough that it became unacceptable in the early 2000s..
Anyways, when you tried to idle it on a cold morning to warm up Read more, the other cylinder bank remained cold. It worked but it was an awful engine.
Yes i see this
2017 WEILER P385 ASPHALT PAVER (A52709)
2017 WEILER P385...
S/N: 1240824 (A55853)
2011 Atlas Copco XAS 375JD6 Towable Air Compressor (A55973)
2011 Atlas Copco...
Husqvarna Riding Mower (A56857)
Husqvarna Riding...
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2008 INTERNATIONAL...
2010 MULTIQUIP 25KW GENERATOR (A55745)
2010 MULTIQUIP...
