Hay Dude
Super Star Member
- Joined
- Aug 28, 2012
- Messages
- 18,903
- Location
- A Hay Field along the PA/DE border
- Tractor
- Challenger MT655E, Massey Ferguson 7495, Challenger MT535B, Krone 4x4 XC baler, (2) Kubota ZD331’s, 2020 Ram 5500 Cummins 4x4, IH 7500 4x4 dump truck, Kaufman 35’ tandem 19 ton trailer, Deere CX-15, Pottinger Hay mowers
Thought I’d post a review on first 4 years & 50,000 miles of ownership on my 2020 RAM 5500 cab & chassis w/ Cummins engine.
So far, I’ve had few issues. The 3 that were notable were:
1. Steering wheel heat failed. I didnt want a heated steering wheel. The truck came with it. It failed in the 3rd year of ownership. It was replaced with a new leather wrapped steering wheel under warranty.
2. DPF tank level gauge failed in 2nd year. The readout on the dash was “E” all the time. Turns out theres a sensor built into the tank that wasn’t reading anymore. It was replaced with a new sensor under warranty.
3. Right side front wheel hub bearing failed. The right side spindle began clicking. This one may have been my fault. I drove truck through some deep water. Nobody knows. It was replaced under warranty.
Those are the 3 failed components in 4 years. Everything else still looks & works excellent. Once in a while, the center stack display in the middle of the dash will go off for 1 second then come back on.
Truck ownership experience: I’d give it an ”A” so far like a low 90’s out of 100. The truck was purchased brand new to pull a heavy trailer and carry all my necessary tools. Does an excellent job of this. Even the de-rated chassis & cab Cummins pulls better than anything previously owned or I expected from this truck. The truck has been asked to do above and beyond its rated capability hundreds of times. In extreme overlaoding situations, the transmission has a slight shutter between 1st & 2nd gear, but only when well overloaded (pulling trailer off road through bumpy soil).
The fit & finish has held up VERY well. It’s a comfortable strong truck meant for heavy duty use, but still retains a comfort & ease of operation.
I’m very pleased and would highly recommend RAM/Cummins/Aisin to anyone.
