RAM 1500 V6 8-speed test.
   / RAM 1500 V6 8-speed test. #11
Dmace, you have to take off the Ram blinders, the power and speed part with unloaded trucks is not that close. If you think they are close, then the little V-6 is even closer to the Hemi since the Ecoboost beats that. But the Ram's V-6 MPGs look great unloaded, and the 8 speed sounds like it performs awesome.
An interesting comment on that other thread points out how similar the performance is between the Ford and Ram when loaded close to each trucks respective limits. They said it looks like they may be honestly rated for towing after all.
   / RAM 1500 V6 8-speed test. #13
Actually it is. Ask anyone who drag races what it takes to gain 5 MPH .7 seconds.
HAHA actually when I first started racing it was pretty cheap to do that but now in the 8 sec bracket it takes an awful lot to do just that!!
   / RAM 1500 V6 8-speed test. #16
Amen GGB, I just bought a new F-150 FXT Crew cab 4x4. It is a beautiful truck, but working on it myself......not going to happen. It is far more advanced than the old 350 that I had when I was in high school. On the plus side I did get a 7yr/100,000 mile bumper to bumper warranty. Hopefully it will be a good truck and I won't have to be bringing it back to the dealer all the time like I did with my 6.2L GMC.
No blinders here...
Even compared to the HEMI that's impressive. In the test PickupTrucks.com did for the best truck under $30k (which the RAM won), they got a 15.76 at 89.64 mph in the quarter mile so it's right between the two trucks. With this new 8 speed transmission though I bet it will beat or match the Ecoboost speed and fuel mileage. No turbos or direct injection needed.
http://special-reports.pickuptrucks.com/2011/09/30k-shootout-quarter-mile-test.html
Also, the F150 was only an extended cab and not a full four door crew cab like the RAM's.
   / RAM 1500 V6 8-speed test. #18
Typical Phord Phan still doesn't get it. If these were two equally comparable trucks that would be a huge difference. Considering one truck is the Top performer for Ford with all this expensive technology (direct injection, twin turbo, etc...) and the other is the base standard plain and simple V6 at the low end of the RAM truck engine line, those numbers are very close. That 8 speed in the HEMI and V6 diesel will really show the difference in comparable powertrains.
That's the beauty of the 8 speed. Makes an otherwise pretty mundane gas v-6 look a lot better. The efficiency of a Diesel engine is magnified when you give is a close ratio, efficient shifting transmission with an extra gear or two over the competition.
GM showed up Ford on speed and towing tests the same way. Back a few years ago when Ford has all their glossy brochures and keyboard racers touting their new 400+ HP scorpio diesel, GM was still able to out pull and outrace the new Ford with a 390hp older dmax. It's also how GM was able to build a consistently faster truck than ford since the advent of the dmax over 10 years ago. GM always had the more efficient transmission with better tc lockup and more locked up gears than ford.
Buddy of mine that owns a local transmission shop for over 30 years and he would show me bench top comparisons of internal parts on opened up GM & ford transmissions since the mid 90's. The consistent theme was GM was always bigger, stronger, more efficient and most of all, less often repaired in the transmission shop. The Allison was an unbelievable leap forward over anything Ford had and forced ford to finally start building something more than a 4 speed car transmission with a bigger torque converter on the front of it. I rebuilt a bunch of them e4ods and 4r100's. Never rebuilt an Allison. Torqshift was big improvement but probably never would have been built util ford was forced to step up to the plate and do it.
Now I don't know how that compares to a "BIL" or neighbor story because I know it's just a guy who's never been on the internet with thousands of rah rah ford posts. He just owned a transmission shop and repaired thousands of transmissions for over 30 years, but I thought I'd share my personal experience.
Transmissions make a HUGE difference in the performance of the engine it is mated to. I would much rather have a lower powered diesel with a 6-8 speed than a more powerful diesel with a 5-6 speed. Fuel efficiency and towing performance is better. That's what these trucks are made for.
   / RAM 1500 V6 8-speed test. #19
I haven't driven one yet but it sounds good, especially for towing.
Yes sir a big advantaqe and better mileage with or without a trailer.
   / RAM 1500 V6 8-speed test. #20
Here is what gripes me. When we get by the obvious baiting idiots that try to pit one brand against another I prefer to stay solution based....the Next Gen approach.
My 2011 F 150 ecoboost heavy duty with 3.73 that out hauls and out tows my 2003 Dodge Heavy Duty (which I loved) gets a strong 17.5 city, and 21.9 on two lane at 68 and 18.5 on interstate at 75mph...whew...it takes a long time to get all that out there to keep the bone heads from challenging stupid stuff. With these electronic trannys that can be easily re programed....well there is a certain consistency with these engines, keep them below 2000RPM like at 1850 they get far better mileage so get your gearing to allow this at 78 mph on the interstate, gives us a switch to make this decision...etc. The next several MPG will come from trannys and ratios.
DEUTZ MARATHON...
Kubota RTV X900 (A53317)
Kubota RTV X900...
John Deere 1025R (A53317)
John Deere 1025R...
ALLMETAL MOBILE PRESSURE WASHER (A58214)
ALLMETAL MOBILE...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
