RAM 1500 V6 8-speed test.
   / RAM 1500 V6 8-speed test. #1
Dmace
Elite Member
Wakefield, NH
Kioti CK20 HST
Pretty neat review of the new RAM 1500 with the base Pentastar V6 and new ZF 8 speed transmission.
http://news.pickuptrucks.com/2013/03/rampage-the-test-at-davis-dam.html
I'm impressed with the fuel mileage numbers for a crew cab 4x2 short bed both empty and trailering 5,500lbs. 23-26 mpg empty and 10.6-11.7 mpg towing 5,500 lbs.
Their praise for the new transmission sounds very promising too!
They compare the numbers up the Davis Dam to the recently tested F150 Ecoboost. Considering the much more powerful Ford had a 9,000 lb trailer vs the 5,500 lb trailer on the base V6 RAM, I'm surprised how close they were. Even empty both trucks were nearly identical in 0-60 and 1/4 mile time and speed. Impressive for a little NA V6 engine.
This 8 speed in the HEMI and V6 diesel is gonna be a real winner!
   / RAM 1500 V6 8-speed test. #2
The tranny is going to be built just up the road from me about 40 miles. Its been big news here and the plant expansion that goes with it.
Comparing the Dodge V6 to the Eco Boost is like comparing a gas V8 to a diesel. Not in the same class.
Chris
Obviously, they only show how it compares since they recently tested the Ecoboost in the same way. Not a direct comparison just the only comparison they have right now.
Since most people think of a base V6 truck engine as weak and slow, seeing the base plain and simple normally aspirated RAM V6 closely keeping up with Ford's "hot rod" Ecoboost engine in acceleration test is impressive. Even a die hard Ford fan can't deny that.
RAM 1500 crew cab (4 full doors) V6 Pentastar- 16.09 @ 88.39 mph 1/4 mile
F-150 ext cab EcoBoost -- 15.37 sec. @ 93.32 mph 1/4 mile
Considering the power difference, 0.7 seconds and 5 mph is not much for similar sized vehicles.
Towing up the Davis Dam:
RAM 1500 V6 towing 5,500 lbs 1/4 mile - 24.35 @ 55.5 mph
Ford F150 Ecoboost towing 9,000 lbs 1/4 mile 24.56 @ 58.47 mph
Not a direct comparison but the I bet the Ford and GM base V6 engines won't be even close to these numbers.
   / RAM 1500 V6 8-speed test. #4
That eight speed transmission is nice, I wish I had that in my truck.
I haven't driven one yet but it sounds good, especially for towing.
   / RAM 1500 V6 8-speed test. #6
The tranny is going to be built just up the riad from me about 40 miles. Its been big news here and the plant expansion that goes with it.
Chris
What's a riad? Could you explain the transitive logic in your post?
   / RAM 1500 V6 8-speed test. #7
Its probbaly a typo and he meant road, the I and the O being next to each other on standard QWERTY keyboards and road making sense on that sentence.
Aaron Z
   / RAM 1500 V6 8-speed test. #8
Actually it is. Ask anyone who drag races what it takes to gain 5 MPH .7 seconds.
   / RAM 1500 V6 8-speed test. #9
I've hung around a few. In the neighborhood of 75HP at those speeds in a boxy truck to make that much difference.
   / RAM 1500 V6 8-speed test. #10
The older I get, the more amazed I am at the continuing improvements in performance from technology from all the manufacturers.
It would be better yet if the engineers actually had to work on what they design, and if the bean counters had to work on what they are approving so they'd be less likely to try to save pennies which end up costing big money to repair down the road. But I'm not an optimist regarding this.......
2015 Freightliner Ambulance (A50323)
2015 Freightliner...
2021 Liebherr L556 (A51039)
2021 Liebherr L556...
2022 Club Car...
2015 Ford F-350 Service Truck with Liftgate (A48081)
2015 Ford F-350...
Pallet of Chains/Binders/Cable Slings (A50860)
Pallet of...
2010 Pontiac G6 Sedan (A48082)
2010 Pontiac G6...
