rally mower giving problems
   / rally mower giving problems #1
uptaker73
Morganton, NC
RK 37, John Deere LX280 John Deere Z535m John Deere 160
I have a 1994 model rally garden tractor that has always been really dependable until lately. Its latest problem is it will run fine on level ground or going down hill. But when you start up hill it will act like it floods itself out and quits. i have to roll it backwards to put it on level ground for it to crank. Any ideas what it may be? The engine is a 18h vtwin briggs industrial commercial.
   / rally mower giving problems #2
Re: rally mower giving problems
<font color="blue">
</font>
Hey UpTaker,
Have you checked the
1. Fuel Filter, should be replaced if it is older than a year or 2.
2. fuel hose for kinks.
3. Air Filter, if dirty clean or replace.
4. Gas Cap to see if the vent is clogged.
5. Spark Plug, replace once a year.
Try these things and then let us know,
Have a nice day,
Joe
   / rally mower giving problems #3
Uptaker, Along with the previous mentioned service checks, I would also have to check float level which is in the carbureator's bowl or it could be the viton needle and seat if it is positioned toward the rear of the engine .
It seems when you go up hill only ,if the fuel is running to the back of the bowl going past the needle and seat it could be causing the flood condition .
Does this mower have a thumb screw at the bottom of the bowl? or is it a spring loaded push button drain.?
Don't you just hate when these little buggers give you greif? /forums/images/graemlins/crazy.gif
All of the regular maintenance issues are ok new plugs, filters and so on. I will look tomorrow and check for the screw on the bowl. Will post what I find. Thanks for all the help so far.
   / rally mower giving problems #5
does the starter turn over after it has stopped? or will the engine just not start?
thanks
Valvoline Transmission Oil / Power Steering Fluid (A53117)
Valvoline...
2017 Chevrolet Tahoe (A52377)
2017 Chevrolet...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A52705)
2019 CATERPILLAR...
1985 Ford Ltl9000 Tender Truck (A53473)
1985 Ford Ltl9000...
2021 CAN-AM OUTLANDER 650 XMR 4-WHEELER (A51406)
2021 CAN-AM...
2017 Can-Am Side by Side (A51694)
2017 Can-Am Side...
