Rake RAKING BEACH W/LANDSCAPE RAKE
   / RAKING BEACH W/LANDSCAPE RAKE #1
polkapoppy
Farm Pro (2003) 2wd diesel
Does anyone have experience raking a beach with a landscape rake(york rake)? The sand is very loose and dry, which makes the wheels of the tractor sink in a few inches.
I have a 20hp Farm Pro, 2 wheel drive, with four stock weights on the front. The front tires are the three rib ag. tires. The rear are V ag tires.The front tires dig into the sand and skid when I'm turning. The rear tires don't seem to have much traction in reverse.
I cannot seem to lift or lower the rake fast enough to compensate for the irregular terrain of the beach. The York rake digs in and stalls the tractor.
POSSIBLE SOLUTIONS:
1) Add gauge wheels to rake?
2) Add more weight to the front?
3) Install wider front tires, i.e. flotation type used on hay wagons?
4) Replace rear tires for better reverse traction? What type?
5) Buy a 4wheel drive tractor?
PLEASE HELP!
Beachcomber
   / RAKING BEACH W/LANDSCAPE RAKE #2
I vote for: 1 Add gauge wheels to rake? That should help a lot. Ken Sweet
   / RAKING BEACH W/LANDSCAPE RAKE #3
I've adjusted the top link in more to get the rake tines to just drag more instead of digging in. The top link adjustment is critical for mine operations. I've found in some instances that a little more speed really helps just have make more passes. bjr
Thank You for that advise I will buy a shorter top link and give it a try...
   / RAKING BEACH W/LANDSCAPE RAKE #6
The wider the gauge wheels, the better. Ken Sweet
1999 Volvo WG T/A Dump Truck (A55973)
1999 Volvo WG T/A...
2007 Chevrolet Silverado 1500 Single Cab Pickup Truck (A55973)
2007 Chevrolet...
2020 Case 5550 Trident (A56435)
2020 Case 5550...
INTERNATIONAL EAGLE ROAD TRACTOR (A52707)
INTERNATIONAL...
10 - 3/16in Plate Steel Sheets (A55973)
10 - 3/16in Plate...
2017 JLG Skytrak 6036 6,000lbs 4x4 Rough Terrain Telehandler (A56857)
2017 JLG Skytrak...
