Rake Rake, Shovel, carrier?
   / Rake, Shovel, carrier? #1
Anonymous Poster
Epic Contributor
I am looking for some good ways to carry a few hand tools on my tractor (JD4100) and also carry a shovel, rake. I was thinking something attached to ROP?
Any ideas?
thanks,
   / Rake, Shovel, carrier? #2
Carl,
How about a gun rack truckers install in their pick-up? Modified and installed on back of ROPS with U-bolts or other such clamping device might be used to carry your tools in a horizontal manner. If you don't need your 3PH, you might want to invest in a small carryall, again maybe modified and compartmentalized to organize all your tools.
   / Rake, Shovel, carrier? #3
Carl -
There have been a variety of attempts to solve this problem and many have been posted on this board over the last year and a half. I can't say that I've got it all worked out yet, but my contribution was outlined in the <A target="_blank" HREF=http://www.tractorbynet.com/cgi-bin/compact/showthreaded.pl?Cat=&Board=implement&Number=19318&page=&view=&sb=&o=&vc=1#Post19318>ROPS Rack</A> thread. It's an old thread, so most of the pictures aren't viewable any more, but you can check these out if you want:
<A target="_blank" HREF=http://acknowledge.com/tractor/L2500DT/photos/ROPSRack.jpg>Basic Construction</A> (Note: it eventually evolved from square tubing to angle iron)
(Magnets obtained online from <A target="_blank" HREF=http://www.wondermagnet.com>ForceField)
<A target="_blank" HREF=http://acknowledge.com/tractor/L2500DT/photos/ROPSRack3.jpg>Completed Rack</A> (Actually, it will always be a work in progress
<A target="_blank" HREF=http://www.acknowledge.com/tractor/L2500DT/photos/RackOptions.jpg>Possible Uses</A> (Interpret this one any way you want /w3tcompact/icons/grin.gif)
Spookily, after I made the thing, I found out that very similar rack.
I will soon be working more on how to carry the long-handled tools. In fact, I'm heading up to the property this weekend, so maybe I can fiddle with that while I'm there.
Good luck, and please let us know what you come up with.
   / Rake, Shovel, carrier? #4
Harv --
This is very ingenious. Have you applied yet for a patent on it. If not, you should as there could be a real market for this. I don't even have my JD4710, but already I want to start planning on making one of these things. I can think of a ton of uses. Thanks. /w3tcompact/icons/wink.gif
Regards,
Bob Ancar
Cambridge, NY
   / Rake, Shovel, carrier? #5
<A target="_blank" HREF=http://www.tractorbynet.com/cgi-bin/compact/showthreaded.pl?Cat=&Board=custom&Number=47430&page=&view=&sb=&vc=1#Post47430>Shovel carrier</A>
   / Rake, Shovel, carrier? #6
This works good IF your tractor has a folding ROPS and IF it's high enough off the ground to keep the handle from dragging! :)
hi:
I have been using a length of ABS pipe 2.5", with a cap glued on, held on with hose clamps to the outside of my loader uprights.
UNUSED FUTURE BF47 47" BALE FORK (A57193)
UNUSED FUTURE BF47...
Gorman Rupp T4A3-B 4in Centrifugal Dewatering Pump (A55851)
Gorman Rupp T4A3-B...
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A57880)
2018 FREIGHTLINER...
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A55301)
Kubota BX2680...
UNUSED RAYTREE RMT48-48" HYD TRENCHER (A57193)
UNUSED RAYTREE...
2014 Ford Transit Connect XLT Cargo Van (A55852)
2014 Ford Transit...
