rake problems
   / rake problems #1
Lone Wolf
Florida
Kobota
Rake is 2 years old but has done this since I bought it. 1 single hydraulic unit that controls both sides of the rake. When I let the rake come done towards the ground it seems the right set of rakes (as you face forward) will hit the ground while the left side set will still be about 1-2 feet off the ground. But here is the problem, with both sets on the ground I try to lift the rake finger off the ground slightly. If not they will be digging into the dirt and putting the hay and dirt/junk into windrows. If I try to bring the right side up slightly the left is still in the dirt. If I try to bring the left side up enough to barley cover the ground-no dirt or junk the right side is way to far off the ground and misses the hay. Frustrated, Thanks
   / rake problems #2
Add another cylinder.
Or don't try to carry the rake off the ground on one side with just one cylinder. You don't have that kind of control, sounds like to me.
   / rake problems #3
Sounds like its out of adjustment ... most v-rakes have an adjustment on each side to counter act this.... just a thought
   / rake problems #4
The nature of the wheel rake design is to run firmly on the ground and, by design,they will pick up everything in the field. Ken Sweet
2013 Freightliner M2 106 Altec AA755 55ft Bucket Truck (A51692)
2013 Freightliner...
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
2018 MDB T5E MDB DISC MOWER (A51247)
2018 MDB T5E MDB...
Hydraulic 50 mm pin thumb (A52384)
Hydraulic 50 mm...
66'' root grapple (A53421)
66'' root grapple...
