Rake or rear blade best?
/ Rake or rear blade best? #1
Fuddy1952
Elite Member
South Central Virginia
1973 Economy and 2018 John Deere 3038E
I'm putting a hydraulic top link on my tractor and wondering which would be more useful, a 3 point grading blade or rake? (Sure I could get both, but which would be used the most).
The horse paddock is sand but they drag straw and poop on it, I'm thinking a rake best for that. Also lots of bare areas in pasture I need to smooth some and seed. A rake better for that or blade?
A rake may be handy for pine needles and leaves.
A blade would get limited use, asphalt driveway snow.
I've been using FEL bucket and I have removable tooth bar. It won't do paddock well.
Thanks.
/ Rake or rear blade best? #3
Rake with drop down blade.
/ Rake or rear blade best? #4
Rake plus added wheel kit for me. Sold the blade and never looked back.
Thanks! So glad I asked. You can't beat personal experience.
Tractor Supply has County Line...I guess they're okay for the money, or is it worth paying more for a better one?
/ Rake or rear blade best? #8
I like my Country wide, but I have light sandy loamy type soil. It does great on my gravel driveway too.
/ Rake or rear blade best? #10
Yup, rake with drop down blade and gauge wheels on the back with hydraulic TNT. Makes a very versatile attachment. Bigger the better regarding gauge wheel diameter and width.
/ Rake or rear blade best? #11
I have a County Line 5 foot rake. Last time I used it, I replaced the top link with a piece of chain. That lets it fall to the low level set by the lift links, but lets it float up when going over high spots to reduce the teeter tottering, see sawing effect. Made a lot of difference in cutting those high spots to fill in the lows instead of digging in deeper when the front wheels went up a high spot.
/ Rake or rear blade best? #12
They are different implements and have different functions by design. Will what you can do with overlap? Sure!
From your description of uses, buy a good quality rake.
Then watch all the used marketplace stuff for a used blade if you want one. Often old ones look rough but still function. The biggest issue with all older implements is QH capability. Typically they are not!
For snow,spend some time cleaning up the blade, you probably want a rust converter, then prime, paint and wax (the wax is similar to wax skis, it helps the snow roll off or so my northern fiends tell me, my area rarely gets the 12” we got this year in 2 storms with a few days in between)
/ Rake or rear blade best? #13
Rake. I used mine for snow with a 2x12 strapped in front of the tines. I suggest you get an 8' rake because when its at a 45 degree angle its a lot narrower. If using rear gauge wheels for smoothing, use a loose chain for a top link. The wheels should set the cut height not the tractor.
2012 EAST 30' DUMP TRAILER (A64277)
2012 EAST 30' DUMP...
2015 CHEVROLET SILVERADO 2500HD (A65643)
2015 CHEVROLET...
100-gallon L-shaped Portable Fuel Tank (A66408)
100-gallon...
Landhonor Mini Skidsteer Combination Bucket (A66408)
Landhonor Mini...
SET 4- 12-16.5TIRES/ WHEELS (A64553)
SET 4-...
MISC PALLET OF TRUCK PARTS (A65643)
MISC PALLET OF...
