raising trusses for pole barn
   / raising trusses for pole barn #1
boomer613
Northern part of AL
Kioti DK40SE /W FEL
I am building a pole barn with 16 foot sides (height for the trusses). Does anyone have any experience of raising the trusses this high? I was thinking of buying a pole boom for my tractor? Is this possible? If so why type of pole boom would I purchase?
   / raising trusses for pole barn #2
I have 12 foot walls and we had a crane come in for a few hours, was WAY easier. With 16 foot walls your peak will be 20 plus feet up. Cost was like $250 for 2 hours and like $100 per hour after that. We got all ours set, 12 of them in under 3 hours.
   / raising trusses for pole barn #3
Your tractor will work for setting low trusses, such as a small garage or shed. Anything with walls higher than about 10 feet will likely require something else. We rented a telehandler (extending forklift) one time that worked great. Your 16 foot walls may require a crane though, depending on the pitch of the trusses.
   / raising trusses for pole barn #4
I would really look a big telehandler or crane. I have set more than my fair share in conditions like you have. It is not fun, takes a lot of experienced carpenters with no fear, and no choice the matter. It could go real bad real fast. Trusses are pretty floppy.
A steel spacer bar that hooks two is a must. If you are set on this you need a plan and that will include building your jib. I don't think any company will make a tool for a tractor loader that do what you want as the risk of failure is beyond great. I love a challenge but setting trusses is enough with out risking life for false economy.
Good luck, pay up the insurance, and say a prayer. :)
   / raising trusses for pole barn #5
You can rent high-lift gear for a few hundred bucks over a weekend. Worth the money.
If you are going to be up in the air pick up a fall arrest harness ($70 at Northern Tool). I strung a bull line that I use for directing tree fall (13K lb breaking strength) between eyes set in the posts at the gable peaks and then clipped into that while I set my trusses and sheathed the roof. It is annoying, but not nearly as annoying to live with a broken back or limb from a fall. Be safe.
Thank you for all the suggestions. I might consider having this done with a contractor. Was trying to save some money but building something 16 feet high might be out of my league.
   / raising trusses for pole barn #7
It really won't be hard as long as you have the right tools. A useful trick to lifting trusses is that you set them upside down, tack a toe block in and then rotate them to vertical using the equipment. My son and I did ours - height off the ground isn't the problem, the span (and hence weight) is the thing to worry about. If you set them upside down and rotate them using the machine or via a pull line connected to your tie off line then it really isn't bad.
   / raising trusses for pole barn #8
Your are correct in your method, but that first ones a real bear with a 16' wall height. Bracing and plumbing are pretty rough with 10'-12' being your max bucket lift. With span and pitch determining peak of ridge every movement is amplified from operator to the end of the jib.
   / raising trusses for pole barn #10
What I did was create a long pole using thick wall pipe about 10ft. long with a spreader bar at the end. Slide it over the end of my bale spear. I was able to lift my steel trusses with vertical I beam into place. My walls are 14ft. and 16ft. in the center.
Good luck
2007 Thomas School Bus  Freightliner Chassis, MBE-900 Diesel (Non-Running) (A44789)
2007 Thomas School...
Chery 20' Bi-Parting Iron Gate (A44502)
Chery 20'...
2016 Ford F-250 Knapheide Service Truck (A44571)
2016 Ford F-250...
2018 Bobcat A770 High Flow Compact Wheel Loader Skid Steer (A42742)
2018 Bobcat A770...
2020 Nissan Rogue SUV (A42744)
2020 Nissan Rogue...
17in Excavator Bucket (A44391)
17in Excavator...
