Raising Rear Attachment on JD 2305
   / Raising Rear Attachment on JD 2305 #1
1greenmachine1
Midwest
JD 2305
I just bought a new JD 2305 and I can not get the rear rack or box blade to raise up all the way. It only will raise up about 6 inches. Only a few times will it raise up all the way and out of the way. Is there something I am not doing right? It really is a problem when I'm moving dirt and want to drive over the dirt pile with out the rear attachment getting in the way when I drive over the pile.
Thanks!
   / Raising Rear Attachment on JD 2305 #2
How far did the lift arms go below the lift pins on the impliment before you hooked it up?
Ron,
I'll check today and will post the measurements. Thanks!
   / Raising Rear Attachment on JD 2305 #4
I don't need measurments... You only have so much lift available. Please forgive me if I get to basic here. If the arms go well below the lift pins, then that is where your lift is being wasted. I am not specifically familliar with your 3PH, but if it is along the standard lines, You should have adjustable links that connect between the upper and lower lift arms. These links, usually a turnbuckle affair, are adjustable in length to fine tune the height of the lower arm. There are also usually several attach points along the length of the lower lift arms. Attaching the links to different points along the lower arms allows you to trade lift force for lift travel. Attaching closest to the tractor on the lower arms gives you max vertical travel at the ends of the lower arms where the impliment attaches, but it reduces the lift capacity to it's minimum. Attaching the links out near the ends of the arms away from the tractor gives the minimum vertical travel, but the greates lift force. Depending on the weight of the impliment, you may have to comprimise the desired lift travel to lift a heavy impliment.
2013 MACK CHU 613 PINNACLE (A48992)
2013 MACK CHU 613...
2016 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A45678)
2016 FREIGHTLINER...
Stoltzfus Hay Wagon (A49251)
Stoltzfus Hay...
2023 Bobcat T66 Track Skid Steer (A49339)
2023 Bobcat T66...
Minneapolis Moline 130 Manure Spreader (A49251)
Minneapolis Moline...
2018 John Deere 652R 52in Stand-On Mower (A46684)
2018 John Deere...
