3-Point Hitch Raising my back blade
   / Raising my back blade #1
Pipestone Kid
Bigfork, Mn.
JD 4110HST
Lately I have noticed that the 3 point hitch on my 4110 doesn't start to raise the back blade until I move the lever about half way up. I still goes up all the way, but I don't seem to have any adjustment in the lower half of the raise/lower lever. Any ideas? Oh yes, I have checked the fluid level (Hydro) and everything else works fine.:confused:
   / Raising my back blade #2
Do you have a rate of drop adjustment knob? I find that if mine on my 2720 is not adjusted properly it won't rise at all. Of course I dont know anything about the set up on a 4110. Maybe you don't have this feature.
Wooden
   / Raising my back blade #3
If you would post a pic from the side showing the blade attached, I think we could point out to you what the problem (not really a problem) is you are experiencing.
I do have a drop adjustment knob. In fact, I recently adjusted it to drop faster--I will check it out. Might be it. Thanks.
   / Raising my back blade #5
Your blade could actually contact the ground with the 3ph lever halfway down. this would make it appear as if the lever isn't doing anything on the way back up until the lever position meets the point of ground contact
Try taking the blade off, or backing the blade over a ditch. I think you'll see that you still have adjustment in the lower half of your lever position, but the blade is in "float" when the lever is at full drop, as the 3ph has no positive down force other than the weight of the implement.
   / Raising my back blade #6
MaJYk
I think you are right on with a very good explanation.
I was trying to think of the words to describe it, but thought if the OP would post a pic then this would be easier to point out.
But you summed it up well for the Pipestone Kid IMO :)
   / Raising my back blade #7
I agree with MAJYk, too. This behavior is identical on my tractor. It's clearer if you think about a plow, rather than a back blade. It hits the ground halfway through the TPH lever travel, and the bottom half of that lever range is "under" ground.
-rus-
That explanation makes sense to me. I will do a little experimenting and let you know if it "solves" my problem. Thanks to all.
Deere 331G (A50120)
Deere 331G (A50120)
2001 Ford Ranger XLT 4x4 Ext. Cab Pickup Truck (A50323)
2001 Ford Ranger...
2003 Fleetwood 2 Axle Camper (TITLE) (A50774)
2003 Fleetwood 2...
KJ Portable Bathroom w/Sink & Shower (A50121)
KJ Portable...
Wolverine Quick Attach 68" Bucket (A50515)
Wolverine Quick...
2017 Ford Expedition SUV (A50324)
2017 Ford...
