Raising lift arm manually
   / Raising lift arm manually #1
MetroX
Milford, MI
2004 Toolcat "B"
My 2004 Toolcat popped a hydraulic line somewhere along the area where the lift arm cylinder resides, promptly dumping out gallons of nice hydraulic fluid. I can't tell which line exactly has failed, I think it is either one of the supply lines for the front attachments on the lift arm, or one of the front drive axle lines. In order to get a wrench on the lines to remove them one at a time, I need to lift the front arm up. I tried lifting the arm with another tractor, but all I could do is lift the entire front of the Toolcat. I though for sure the lift arm bypass valve (red knob under the dash) would have let it go up, but apparently this is just there to allow the arm to drop down without hydraulic power. Anyone have experience with lifting the arm manually?
Rich
   / Raising lift arm manually #2
Rich
There is a procedure in the manual to lower the boom without starting the motor. That should allow it to be raised with another tractor.
Unfortunately, the lift arm bypass feature does not allow the lift arm to be raised by another device, it apparently only bypasses the lower cylinder circuit. I had to remove the line from the control block under the drivers seat, then lift the arm (I used an engine crane) until I could place the safety device on the cylinder to hold the arm up. I lost about another gallon of hydraulic fluid doing this, just to add insult to injury.
2013 GMC Yukon Denali 4x4 SUV (A51694)
2013 GMC Yukon...
NPK GH15 HYDRAULIC HAMMER (A52472)
NPK GH15 HYDRAULIC...
2008 STEPHENS 220BBL CRUDE OIL TRAILER (A52472)
2008 STEPHENS...
2025 New/Unused Wolverine 48in Skid Steer Trencher (A51573)
2025 New/Unused...
JOHN DEERE S780 LOT NUMBER 36 (A53084)
JOHN DEERE S780...
2022 JOHN DEERE 410E II (A52472)
2022 JOHN DEERE...
