Raising 400cx Loader while in dump position question
   / Raising 400cx Loader while in dump position question #1
Engine66
Orange County, CA & Vermont
JD 2305 & 4720/400cx/BH448
I have been using my new 4720 with 400cx loader and so far have been very satisfied with the various features. One issue I expreince is while raising the 400cx loader from the full dump position located on the ground, it raises approx 1/3 up and stops until I adjust the bucket positon to a more upright position and then the loader continues to raise. Example...if I use my bucket hook or grapple to lift an object with the bucket edge vertically facing the ground, I have to level out the the bucket slightly to raise the loader. I assume this is something related to the self-leveling feature, but not sure. Any ideas or should I call the dealer? Overall, everything is operating stellar...just getting used to a few different features. Thanks for any input.
   / Raising 400cx Loader while in dump position question #2
I would bet that is the case, the linkages are probably just at there max travel.
   / Raising 400cx Loader while in dump position question #3
I would also agree that it is part of the self-leveling feature. If you look at the stops/cylinder strokes while it is happening you'll see what's going on. I originally had a 542MSL loader, but once I found out how limited the curl/dump was, it was too much of a sacrifice for me. My dealer swapped it out.
At least you can get to a full dump near the ground. On the 542 MSL, the bucket had to be ~8' (yes feet) high to get a full dump. The curl/dump cylinders on the MSL had a 12" stroke, on the non-MSL they have a 20" stroke. It makes a huge difference.
I made a detailed post in this thread...
bjcsc...thanks for that thread...helpful. I do have a grapple and do mostly dirt work, limited pallet work, and some loader lifting of various objects with the hooks on my loader. I know there are pros/cons to self-leveling and I see your point. I need more hours...at 15+ now, but so far I like the feature and will have to adapt to the work at hand.
While redoing my 300' driveway with my orange tractor, I had about 40 tons of crushed stone to move around. Load after load of lift, move, dump, spread, etc. I had 2 occasions of lifting full loads and having back-spillage onto my hood. I like to remember this as "Operator fatigue" but it was stupidity and lack of attention after a long day. A self-leveling feature may have helped.
I'm split right now and think both arguments for and against are valid. Time will tell after I log more hours. Thanks again for the info...just glad it's not a problem that needs repair.
   / Raising 400cx Loader while in dump position question #5
E-66 thanks for bring that to my attention. I have had my 4520/400cx for two years and never noticed. Sofar that has not been an issue with my operations and I loaded a lot of dirt last summer. I could see if you were making a straight down grap with a grapple where it would be nice to know it in advance so you can plan work.
have fun.
TEW
2017 Chevrolet Colorado Crew Cab Pickup Truck (A55788)
2017 Chevrolet...
(8) 10" IBEAMS UP TO 9' (A54756)
(8) 10" IBEAMS UP...
2008 Ford F-350 Service Truck (A55788)
2008 Ford F-350...
(APPROX 23) 2" X 2" X 20'- 3/8" THICK METAL TUBING (A54756)
(APPROX 23) 2" X...
1991 GMC TOPKICK CHASSIS TRUCK (A54756)
1991 GMC TOPKICK...
