Raised Deck?
/ Raised Deck? #1
Ghost River Retrievers
Benton County, MS
New Holland
I have a 6' bush hog rotary cutter and need to cut some weeds, mainly johnson grass. The issue is that I'd like to cut it to about 24" high (this may seem ridiculous, but it has to do with training dogs). So is it unsafe to mow with the deck raised that much? If not, is it unsafe to cut with the deck raised to 12"?
Of course, this would be with NOBODY else around.
Thanks,
/ Raised Deck? #2
Just thinking outside the box here.
Couldn’t you attach longer chains skirting the cutter so at a minimum the object would slow down substantially?
Also if you have a cab and have mowed the area short previously I wouldn’t worry near as much.
/ Raised Deck? #3
I would mostly be concerned about safety. With the PTO off, raise the deck, get off, and check the angle of the PTO shaft. If it is just a little, will not hurt, but not 20 acres.
/ Raised Deck? #4
The biggest problem would be the driveshaft angle being too out of line.
I used to cut palmetto's by raising deck all the way up and back into them and lower deck slowly.
Chewed them all the way to the ground!
Gotta love a Stump Jumper!
/ Raised Deck?
Thanks for the replies! The angle looks okay. I値l try it tomorrow if it痴 dry enough, but the forecast isn稚 looking promising.
/ Raised Deck? #6
If you have mowed this area before and you are cutting "GRASS" and not limbs or trees there should not be anything to "TROW". Grass will itself is not that heavy to travel far. If you were cutting trees would feel different.
/ Raised Deck? #7
I think you will be OK. I have cut with the mower raised. 24 inches high is not extreme.
/ Raised Deck? #8
yeah I sure wouldn't want to cut anything with it that high that would produce any projectiles coming at me :)
Landhonor 8' x 6' Metal Shed (A66408)
Landhonor 8' x 6'...
Wooden Swing (A64557)
New/Unused Wolverine 3 Point Hitch Attachment (A65583)
New/Unused...
Toro Workman Utility Cart (A64553)
Toro Workman...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
2012 INTERNATIONAL DURASTAR 4300 SBA 4X2 CHIP TRK (A63276)
2012 INTERNATIONAL...
