raised bed garden?
/ raised bed garden? #1
anthonyk
houston texas
Century 3647
Another question for any of you serious farmers or gardeners:
My land is mostly clay. By that I mean real clay. 4 inches of topsoil, then 30 feet of that grey thick clay that if it gets wet, sticks to you like road tar.
I've dug down about 25 feet with the backhoe doing the pond, and never broke out of it.
So my problem is that it's hard to plant anything.
I'd like a small garden next spring, maybe 20x20 and I was wondering if a raised bed would be the way to go.
If so, how high should I make it? I was picturing a box frame made of 2x12's and filling that with load of good dirt or topsoil. Then fencing the whole thing.
Any tips, suggestions or ideas would really be appreciated.
Anthony
/ raised bed garden? #2
If you want raised beds, think of how deep the roots of the plants you plan to grow will penetrate. Carrot and potato's will need deeper soil than beets or melons.
That said, 2x12 should be more than enough. If you are going to fill the beds with purchased soil have a soil sample done before you purchase it. I'd suggest mixing compost with the soil, along with a little sand. It's easier to amend the soil before it gets into the bed.
Consider making several beds 4' x 24' with a walkway between them, that way you can weed the beds without compacting the soil.
Have fun in the garden!
thanks, that 4x24 idea never crossed my mind.
that's a good point:)
anthony
/ raised bed garden? #4
Landscape timbers have been on sale at the big home improvement centers this summer for about $2.00 per piece. I bought 105 of them and just finished constructing 7 raised beds that are 4' wide by 16' long by about 9" deep. (each timber is about 8'x5"x3", so 15 were used for each of my beds.)
I spaced mine about 2.5' apart, parallel to each other. My good soil was about 4" deep, so I was able to use the soil from between the beds to add inside the beds to bring the levels up to nearer the top of the beds. Compost and sand will make up the rest the soil in the beds.
In between the beds, I am using some scattered 12" square pavers that I got very cheaply at an auction, with sand spread around the pavers and landscape fabric beneath.
It all sounded like a good idea when I started, but between the cost of all materials and the time needed to level the ground and the timbers, it became expensive. I spent most of my free time in August working on it. Looks great so far though, and it should last 8 or 10 years. My heavy soil cost me much of my garden the last two years due to excessive rains that killed the seedlings.
/ raised bed garden? #5
I think ToadHill's and Scott's posts provide a pretty comprehensive reply. For emphasis I'd like to repeat the suggestion of "making several beds 4' x 24' with a walkway between them". The initial cost for the lumber is quite a bit higher, but it's worth it. It's much easier to access your plants with the walkways in between the beds, and, as ToadHill says, you don't compact the soil by tromping on the soil the plants are growing in (especially when the soil is damp after a rainy spell and you really need to pick those beans).
There's controversy about whether it's ok to use treated lumber for your boxes. Personally, I would use treated lumber, but I'd avoid growing root crops (carrots, potatoes, etc.) where they might be near the treated lumber, at least for the first year or two.
One other suggestion: Tie your 2 x 12's at the corners with straps. You can buy galvanized steel reinforcements (Simpson Strong Tie is a well known brand, but cheaper brands are available, ask for "joist hangers" at your local "home center" and you'll find the corner reinforcements nearby) or you could buy a roll of strap for hanging pipe in the plumbing department (this might be copper or at least copper plated which might look nice in your garden). Fold a piece of the strap around the outside of the corner where the 2x12's meet and nail the strap to the 2x12'. Use galvanized nails (preferably the galvanized joist-hanger nails). All of this hardware should be available at your local builder's store or big box (Lowe's or Home Depot, etc.).
For a reference, to fill a 4' x 24' bed 11" deep would require about 3-1/4 cubic yards of topsoil. A single 20' x 20' bed 11" deep would require 13.6 cubic yards.
Totally off topic, but... Never burn treated lumber!! The smoke can cause serious breathing problems. I've personally seen this happen to an individual.
/ raised bed garden? #6
Another option is railroad ties. Several of my nieghbors have built beds out of them. I can get them for around $7-8 each here, but have no idea what your cost might be.
/ raised bed garden? #8
You could dig some of the clay out where the beds are going to go to get soil more depth. Say down 12" with a hole and up 12" with boards and you have 2feet of soil for root crops. This can save you some $$ on boards. Downside to this is that if that clay does not drain at all then it would turn into a bathtub under your raised beds.
Fall is coming and you could treat those empty raised beds as trench compost piles. Just start throwing all the grass, leaves etc you can in there. Being where you are it should break down nicely all winter long with some watering to keep it moist and a little turning/tilling. Come spring throw on some soil, till it in and you should be good to go.
Charles
/ raised bed garden? #9
anthony
I like them 3 feet wide. With 4 foot wide ones the center of the bed is 2 feet away. To reach the center you have to put a foot in the bed or suport your body some how because you will be leaning out past your center of gravity.
/ raised bed garden? #10
I'm using concrete blocks. The holes in the blocks turn out to be useful for holding pcv pipe sections, as for a cold frame, or sections of cattle panels to support vining crops, etc. My wife wants to plant marigolds and other insect repelling flowers in the holes. The blocks last basically forever, and are cheaper than the decorative blocks. You may find used ones, but I went to a local producer and bought seconds for about 60 cents each. For a 4x24 bed you need 42 of the 8x8x16 blocks (or the 6x8x16 if they are cheaper). You could always stack them if 8" isn't deep enough, but I'd probably just amend the soil under the bed to make it as deep as I thought I'd need with one layer of blocks. My dirt is actually pretty good, so good in fact that I have lots of weed problems. I find that having a defined raised bed not only gives me the benefit of amending the soil, but also makes weeding easier when needed. As a last resort, when the weeds in a bed got away from me, I simply covered the whole bed with plastic and let the sun do the weeding for me.
Chuck
/ raised bed garden? #11
3' wide is nice; it is easier to reach from either side. 4' wide is the max, unless you want to actually get in to the box to do necessary work.
3' between beds is nice; my wife's garden cart fit thru easily. We set a couple narrower; pain in the behind getting a cart between for mulch, compost, cleanup etc. It is easy to lean over from either side.
Another thing is if you can keep access to one side of the beds for the tractor for filling etc.
Depth of bed is dependant on root depth of plants. Sunset Garden books are a good reference...
anthony
Guys, those are all great suggestions!
Thanks mucho!
Anthony
/ raised bed garden? #13
I made raised beds for a 4H group of first time gardeners this year. Four beds 20' x 4' with 5' between so I can mow. Each kid has 4'x6' of clear space. I used 20' x 8"-12" firewood logs & ripped them lengthwise with a chainsaw. Stood on edge with the bark side in & pinned with rebar stakes. Smaller diameter cross pieces about 6' apart. Filled with composted dirt & woodchips I've had for about 5 years. Oriented east & west with 5' fence trellis on the north side. Kids grew carrots, green beans, green peppers, tons of tomatoes, cukes, egg plant, radishes ( only failed crop, all tops - how do you not grow radishes ????) pumpkins, zuccinni, summer squash, beets, spices?, marigolds. Did a display of pictures, plans, etc & got a blue ribbon at local fair in July. Kids were able to reach to weed by kneeling on the logs. High density planting resulted in amazingly few weeds. Kids got bored at first but got enthused by the ribbon & subsequently by the produce. Was a good experience& I can salvage the firewood if they're not going to plant next year. MikeD74T
/ raised bed garden? #14
For gardening organic vegetables using landscape timbers or railroad ties is questionable because of the chemicals they are treated with. I use 8"X8"x12" solid cement blocks. I have had more success with raised beds than row gardens because of the weeds. I tried 4' wide gardens and they are just a tad too wide so now I have 3' wide beds. Make sure you place the rows far enough apart so you can ride and mow easily. Fill the beds with finished compost and you are ready to go.
/ raised bed garden? #16
Jim, that design is interesting. At 30' long, 20" wide and 14" high, at $1.36 a sq. ft. it sounds about right. It is interesting that the beds are put close together so you can use a 2x6 on the tops of the beds to use as a seat for weeding. The treated wood is only at the top edge and would not be in contact with the soil so it "might" be OK organically also.
One question: Where do you buy sucker rods?
/ raised bed garden? #17
Don, I think you could use 5/8" rebar to do the same thing, but you might find sucker rods at the same places that sell old pipe for fencing. In another article on this website, they talked about using 5/8" rebar instead of sucker rods. I think you could even drive down forms stakes, but they would not last as long as the rebar/sucker rods unless you made the stakes yourself from treated lumber. The most interesting part of this design to me is the corrigated metal. Since I have an old barn to tear down, I'd say I have plenty of raw material I could recycle for this use.
Here is another link to the Noble Foundation site where they have lots of interesting articles on hoop houses and projects with real numbers for commercial production. They are also very honest about the mistakes they make and where improvements are needed. I just like the site in general.
Noble Foundation Horticulture Index
/ raised bed garden? #18
Jim up here in the north east we many us hoops over the raised beds to get an early start and also to extend the season.
We just did our last planting of greens and I will set up the hoops next week with open ends. With any luck we will be eating fresh greens right up to the end of November.
The are talking chance of frost here this weekend. Hate to see summer go away, but the bugs are gone too and the new apples are out so it is a great time of the year.
Hey Jinman, thanks for that link!
I like that idea a lot!
Anthony
/ raised bed garden? #20
A second thanks for the link, jinman.
For other readers not familiar with the term "sucker rod", it's a steel rod about 25' long which is part of the linkage down to the plunger in the pumping system in oilfields. Here in coal country we use "roof bolts" for steel rods for stakes and the like. I think 5/8" rebar would suffice, or maybe 3/4" if you want extra rigidity.
