Rain in diesel transfer tank
   / Rain in diesel transfer tank #1
petebert
Outside of Ann Arbor
Left the cap off on my diesel transfer tank. Rained about a 1/4" with it off so some water got in there. Probably 10-15 gallons of diesel in there right now. It's a cylinder shaped tank. Will the water go to the bottom? It's a bottom feed tank. So if so I was thinking of just letting a gallon out of it.
   / Rain in diesel transfer tank #2
Yes water is heavier then diesel, I would drain several gallons out.
You can save it till winter when it gets cold the water will freeze and be easy to separate.
   / Rain in diesel transfer tank #3
Not enough to worry about , condensation will put more water in a tank than 1/4 inch in a 2 or 3" bung hole
   / Rain in diesel transfer tank #4
I always keep a tube of "Water finding Paste" on hand to check all my tanks. Rub it on a stick, stick stick in tank, remove stick and check for color change. You will now know if and/or how much water is there. Then drain and be happy!
   / Rain in diesel transfer tank #5
No idea where I bought it but had water in tank and found a cloth type tube (sort of like a big wick) that absorbs water out of fuel. Most likely M5farms is correct, get additive to help with the water.
2015 Ford F-350 Utility Flatbed Truck (A51692)
2015 Ford F-350...
2018 Toro Workman GTX Electric Utility Cart (A54811)
2018 Toro Workman...
1981 LOAD KING BELLY DUMP (A53843)
1981 LOAD KING...
2013 FREIGHTLINER CASCADIA SLEEPER (A53426)
2013 FREIGHTLINER...
U56 ELECTRIC FIRE PUMP MOTOR (A51406)
U56 ELECTRIC FIRE...
