Working rail roads and their tracks.
   / Working rail roads and their tracks. #1,961
WOW! Looks like I have a pretty good memory as a then 6 year old.
You might find this interesting. Takes about 10 minutes to read. The train was going 70mph out at Bendix, the brakes failed, the emergency brakes failed after slowing it to 40ish mph, the train swerved violently through the S curves, took out the catenary wires, killing possibility of reversing the traction motors, and proceeded into down town, taking out 6 cars and crashing at the end terminus. There were 5 lines in the end yard, not 3, but I was 6 years old, so, hey! 🙃
   / Working rail roads and their tracks. #1,965
Modern narrow gauge, meter gauge, Brazil.
Bruce
Interesting locomotive, at first I thought it might have been an ex-UP GE U50 with the BBBB truck arrangement, but the U50s had radiators at both ends of the carbody for dual prime movers, but this one only had a radiator on the rear, so most likely has only one prime mover. Cab is similar to the comfort cabs used on most North American locomotives. Almost looks like a stretched Dash 9.
   / Working rail roads and their tracks. #1,966
Here it is:
And a new order,
Bruce
   / Working rail roads and their tracks. #1,967
Here it is:
And a new order,
Bruce
Looks like my guess on a stretched Dash 9 was correct.
Why they would opt for four trucks instead of two three acle trucks is interesting, especially since it is a lightweight locomotive. Maybe because of axle load limits?
   / Working rail roads and their tracks. #1,968
Smaller traction motors can't handle as much power as standard gauge motors, so they need more of them to handle the horsepower.
Bruce
2015 Mack GU813 Mixer Concrete Truck, VIN # 1M2AX13C0FM028499 (A51572)
2015 Mack GU813...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
2009 Freightliner B2 School Bus (A51692)
2009 Freightliner...
1991 Grove RT740B 40-Ton Rough-Terrain Crane (A51691)
1991 Grove RT740B...
2005 International 4200 Texoma UC-301 Pier Drilling Truck (A52377)
2005 International...
Bradley Electric Smoker and Cover (A51573)
Bradley Electric...
