radius rod ball end, Case DI
   / radius rod ball end, Case DI #1
dieseldave56
Deschutes National forest
1951 Case Model DI
Howdy , I'm looking for a radius rod pivot ball end that attaches to the U shaped radius rod. The ball pivot fits into the cap and seat casting on a solid axle ( or spring mounted axle) on my 1950 Case DI . The pivot ball is riveted to the rod, so an assy would be fine. My parts book calls out 02515AB as the part number. thanks, dave
   / radius rod ball end, Case DI #2
Might be something you have to build.. other than that.. try wengers of PA.
soundguy
Thanks Soundguy, I will.
Another tractor forum responced with his experience with this problem. Locate a round bearing that is large enough. Aneal it and weld an threaded section that will attach to the U shaped radius rod pivot ball mount. That is a do-able approach.
dave
   / radius rod ball end, Case DI #4
If you do weld some threads to a bearing.. counter drill it a bit and slip the shank into the bearing, and then weld it up.. it will hold better than just glyueing the shank to the surface.
Heck.. even better will be to drill and tap the bearing for threads.. thread the shank in, AND then weld it!
soundguy
Found a good replacement pivot ball for the radius rod retainer. I used a clutch pivot ball off a '67 big block Corvette. Works like a charm and cost < $15 shipped.
   / radius rod ball end, Case DI #6
Nothing quite as satisfying like finding a cheap will-fit part.
soundguy
Deere 333E (A50123)
Deere 333E (A50123)
Caterpillar 56in Excavator Bucket (A51691)
Caterpillar 56in...
1999 LinkBelt HTC8650 50 Ton Crane Boom Truck (A53117)
1999 LinkBelt...
Serco 200F Log Loader (A52384)
Serco 200F Log...
CAT 257D (A50123)
CAT 257D (A50123)
2005 Freightliner M2 106 Dumpster Carrier Truck (A51692)
2005 Freightliner...
