Radio installation for cab kubota
   / Radio installation for cab kubota #1
teddydo
Mississippi
4330 Kubota, 600 ford
I have a radio to mount in my cab of a 4330 kubato. Do I have to take off the top? If so how does it come off. thank you teddy
   / Radio installation for cab kubota #3
I never have counted them, but there is about a dozen or so screws that hold the roof on. They are Phillips head screws that are inside the cab. Take those out and the top simply lifts off. While you have the roof off to install the radio, it is a good idea to go ahead and put some insulation inside the top of the roof. The recommended type is the aluminum foil covered bubble wrap stuff. You can buy it at Lowes or Home Depot. I used the recommended 3M spray adhesive to hold the insulation in. The type I mentioned will not hold any moisture and does a good job of keeping the cab cool on the long hot days. If you think your A/C worked well before, wait until you insulate the top of your roof. Just imagine your house without insulation in the attic; same thing.
The radio is easy to install and there is already wires run for the speakers and all. You will need an antenna too. My Kubota dealer goes to NAPA and buys the "rubber ducky" type. He prefers those to the Kubota antennas. Good luck!
   / Radio installation for cab kubota #4
Just a thought.
When I installed a radio in my L4610, I chose to try just laying the antenna inside the cab attic space because I can't seem to keep an exterior antenna on another tractor I have.
Has worked good for me for 4 years.
Thank all you fellows. The insulation sounds like a fantastic idea. And Neal I had heard it mentioned before the antena will work just layed down like that. I bough t the radio at the junk yard, some small speakers at Radio Shack and the antenna at autozone. I look forward to having it....thanks ted
2020 CAT 308 (A53317)
2021 JOHN DEERE 6145R TRACTOR (A59823)
2021 JOHN DEERE...
ASSET DESCRIPTIONS & CONDITION (A59904)
ASSET DESCRIPTIONS...
2017 INTERNATIONAL PROSTAR TANDEM AXLE SLEEPER (A59905)
2017 INTERNATIONAL...
2016 Jeep Compass 4X4 SUV (A56859)
2016 Jeep Compass...
2017 Ford Explorer AWD SUV (A59231)
2017 Ford Explorer...
