Radio for rops
   / Radio for rops #1
kjg26
Buford, GA
2013 Kioti DK55
I have a kioti DK55 ROPS. I've made a cover out of a gold cart top. I'm wanting to install a radio and speakers. Im thinking marine stuff should do fine. But do I need to have then in any sort of enclosure or can they be just mounted ?
   / Radio for rops #2
I had a few boats with built in radios & they where always inside the cabin including the speakers , The only radio I had exposed to the elements was the emergency marine radio with the speaker built in & that was somewhat covered under the canvas top & I would always remove it when it was not in use & the radio I just bought for the tractor is made for a roof install with a built in speaker & is design for use with a tractor & I've seen some radios design for tractors where they could be mounted on the rear fender with built in speaker. I would IMHO make sure they are covered or it's made to be exposed to the elements.I found my radio at Northern Tools.
   / Radio for rops #3
Just get something weather proof. The speakers should have their own enclosures, like outdoor speakers do, or they will sound like crap.
   / Radio for rops #6
You will find that the radio is underwhelming against the tractor noise. I used a rugged radio meant for a skid steer-Jensen I believe and the speakers don't cut it. I used my 3M $50 radio headphones plugged into the auxiliary port on the radio until that stopped working, now I rely on only the radio/headphones . It's just too noisy for a radio.
   / Radio for rops #7
   / Radio for rops #8
Can You post any pictures of what your working with:unsure:, Also check out the link bindian posted.
   / Radio for rops #9
I'm telling you guys that I went into my canopy/radio project with just as much enthusiasm as you all. Make sure you have a headphone jack, you'll blow out the speakers trying to hear anything from your radio with the tractor running.
I didn't check out Brandi's link, but searching "tractor radio" will bring this kit up by Jensen including the speakers.
A good friend has the factory cab on his M7040 kubota and he's not able to hear his radio either. Maybe it takes a Deere "R" model cab?
16ft x 8ft Flat Bed (A57454)
16ft x 8ft Flat...
2011 FORD F350 SERVICE TRUCK (A52707)
2011 FORD F350...
2021 Deere 331G (A53317)
2021 Deere 331G...
2023 Load Trailer (A55787)
2023 Load Trailer...
2020 ASV RT-120 FORESTRY SKID STEER (A52709)
2020 ASV RT-120...
(2) HOT FUDGE DISPENSERS (A58374)
(2) HOT FUDGE...
