radiator
   / radiator #1
mwells4654
Antlers, Oklahoma
International 404 & Shibaura SD2600
I own a Shibaura SD2600 and I was told it is the same as a Ford or New Holland 1900. I need to purchase a new radiator but in looking at the parts list the 12 7/8 inch tall radiator (which mine has) is for a 1700 series tractor. The 14 7/78 is for the 1900 series. If I purchase the larger radiator will the shroud fit correctly or should I just go with the smaller radiator?
I did not purchase the tractor new so I do not know if this is the original radiator or not.
Thanks
Mel
   / radiator #2
Thanks
Mel
I would think the same size radiator would be easier to install .The larger one probably could be used ,but would have to be modified to hook up correctly. Have you checked Ebay for this part for a better price.
   / radiator
I have not looked on Ebay but I have found a new one for $353.00. I feel that is a reasonable price for a new radiator.
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
LOT: Assortment of PVC Pipe (A59076)
LOT: Assortment of...
2003 Ford F-750 Truck Highway HM25 Hydraulic Pressure Digger Truck (A55973)
2003 Ford F-750...
TEST YOUR BID BUTTON! (A58374)
TEST YOUR BID...
2021 TAKEUCHI  TB260 (A58214)
2021 TAKEUCHI...
2009 Ford Crown Victoria Passenger Car, VIN # 2FAHP71V79X115619 (A57453)
2009 Ford Crown...
