Gregster613
Platinum Member
- Joined
- Apr 19, 2009
- Messages
- 695
- Tractor
- 273 TYM. 2009 //Yardmachines 7 Speed Shift-on-the-goScotts L2048
Hi guys,
I've got a question for all. I was moving some dirt yesterday [outside temps were warm but not excessively hot] it was dusty when loading & dumping bucket and after about the fourth haul I started smelling antifreeze sizzleing; I jump down - look - and yes the overflow spout was spitting out antifreeze? The tractor temp gauge was only in the middle - ie not overheating at all?? - I'm going what the heck is up with this?
I had checked the radiator screen before I even started up the tractor and it was clear & clean. I learned to to that shortly after I first owned & began operating this beast. I keep the screen clean and I usually also flush out the radiator with a slow stream of water from the hose after cleaning the screen. Except in the lower middle area that I just cannot get anything in to reach adequately. However, this is not the first time that it's spit out the overflow tube. So I wonder if I've got something going on that I need to check out??
Should I just add more antifreeze? Not worry that it does this strange thing? What more is there to check on? Anyone find a way to reach the lower middle area of the radiator with a water hose? Has anyone else with a 273 experienced this happening while radiator screen is clean? Need I worry? Has anyone replaced the stock radiator cap with an after-market? (I haven't, but am wondering if maybe the cap is suspect?) Open to sugestions, ideas on this weird issue.
Thanks, Greg
Thanks, Greg
