Radiator Screen?
/ Radiator Screen? #1
eightksi
Cranberry Twp., Pa
198? Satoh Buck S470d
Has anyone fabricated or use a removeable radiator screen? I was brush mowing christmas tree fields with my brother-in-law's Kubota 2320, and I liked the idea of removing that screen, shaking off and washing off all the junk that would've gone into the radiator fins, and re-inserting it. I have a S470d, and the outside black mesh grill is there, and stops the larger stuff from getting into the radiator, but a whole bunch makes it into the radiator. My Dad's MT250d has a screen on the radiator.
I was thinking of doing a home-depot type thing with it...but I figured I'd ask here first.
/ Radiator Screen? #2
There is a place to slide one in on the Buck but I don't have one either.
/ Radiator Screen?
OK, I see those two tabs on the back of the front Grill. That must be where one would attach. Shouldn't be too hard to attach some kind of a screen to that.
/ Radiator Screen? #4
I've thought about making a wood frame to go in there, just like an old screen door. Would fit my Buck and the 1450 Mits.
/ Radiator Screen? #5
I would measure the space then go to a glass shop. They either make screens or know where to have them made.
Its just a junk-catcher. You don't need a high precision fit.
/ Radiator Screen? #6
I went to the general store and picked up one of those 24x24x1/2 multi-fit hvac filters, cut it to fit and used it. It sounds too simple to work, but it does. I still have to wash out the radiator occassionally, but it works better than the stock mesh screen. Drop $7, give it a shot.
/ Radiator Screen? #7
Why not maybe get some expanded metal from the hardware store and simply cut to fit?
By that I suggest the size mesh generally used as fireplace screening or spark arrestor mesh.
That size would keep out bugs leaves and such.
/ Radiator Screen? #8
Both good ideas, why didn't I think of that. Guess it was too obvious/easy.
Bush Hog 13414 (A64126)
Bush Hog 13414...
2004 International 4400 Single Axle Dump (A62613)
2004 International...
2011 John Deere 5085 70HP Utility Tractor (A60352)
2011 John Deere...
Mini Skid 6 Way Blade (A56438)
Mini Skid 6 Way...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
