Radiator Screen?
   / Radiator Screen? #1
eightksi
Bronze Member
Cranberry Twp., Pa
198? Satoh Buck S470d
Has anyone fabricated or use a removeable radiator screen? I was brush mowing christmas tree fields with my brother-in-law's Kubota 2320, and I liked the idea of removing that screen, shaking off and washing off all the junk that would've gone into the radiator fins, and re-inserting it. I have a S470d, and the outside black mesh grill is there, and stops the larger stuff from getting into the radiator, but a whole bunch makes it into the radiator. My Dad's MT250d has a screen on the radiator.
I was thinking of doing a home-depot type thing with it...but I figured I'd ask here first.
   / Radiator Screen? #2
There is a place to slide one in on the Buck but I don't have one either.
   / Radiator Screen?
OK, I see those two tabs on the back of the front Grill. That must be where one would attach. Shouldn't be too hard to attach some kind of a screen to that.
   / Radiator Screen? #4
I've thought about making a wood frame to go in there, just like an old screen door. Would fit my Buck and the 1450 Mits.
   / Radiator Screen? #5
I would measure the space then go to a glass shop. They either make screens or know where to have them made.
Its just a junk-catcher. You don't need a high precision fit.
   / Radiator Screen? #6
I went to the general store and picked up one of those 24x24x1/2 multi-fit hvac filters, cut it to fit and used it. It sounds too simple to work, but it does. I still have to wash out the radiator occassionally, but it works better than the stock mesh screen. Drop $7, give it a shot.
   / Radiator Screen? #7
Why not maybe get some expanded metal from the hardware store and simply cut to fit?
By that I suggest the size mesh generally used as fireplace screening or spark arrestor mesh.
That size would keep out bugs leaves and such.
   / Radiator Screen? #8
Both good ideas, why didn't I think of that. Guess it was too obvious/easy.
Tailgate For Pickup Truck (A53117)
Tailgate For...
2007 GMC C4500 Mechanics Truck (A52384)
2007 GMC C4500...
19200 (A50324)
19200 (A50324)
Hydraulic 50 mm pin thumb (A52384)
Hydraulic 50 mm...
2019 Ford F-350 XL (A50123)
2019 Ford F-350 XL...
