Radiator repair if any
/ Radiator repair if any #1
Palmerroid
Texarkana, Tx
2008 kubota M5000
Has anyone successfully repaired the plastic neck on the bottom of the radiator? I guess I had a limb come up from underneath and cracked the neck where the radiator hose connects. It's right at the base of the neck where the main radiator is. It cracked at the bottom and about three inches to each side. Will permatex or JBWeld work on this plastic? A new radiator is really expensive. The tractor may be newer than that because I can't find a aftermarket one anywhere. Is there anywhere that I could buy just the bottom plastic tank? You would think that it would be a must that dealers put removable skid plates on any tractor of this size. A mostly rotten limb ended up doing this damage. I've been in a custody cas with my ex,, so I don't have the money just to buy a new one. Any help would be appreciated!!
/ Radiator repair if any #2
I don't know of any DIY fixes but I'm sure there is some. Radiator shops repair the plastic ones but you'd have to remove the radiator. I bought a new radiator for my little truck because of a leak where the plastic meets the metal then I found out later that it could be repaired. I thought they were disposable. Might go on you tube to find a way to repair it yourself ? Hope you get it going cheaply.
/ Radiator repair if any #3
Here is a recent thread that might help: http://www.tractorbynet.com/forums/owning-operating/350419-need-repair-pin-hole-leak.html
I recommended 3M 5200
/ Radiator repair if any #5
I would ONLY use a two part epoxy type adhesive for the repair and make sure it is perfectly clean (use acetone or brake clean) and scuff up the surface.
Also use some kind of mesh to re-enforce the repair.
Remove it for best access and make sure to do it in a warm place allowing for cure time.
/ Radiator repair if any #6
I wonder if Bondic or any of that type of plastic repair would work?
Shop Bondic | BondicUSA
This product seems like it would work best, because it is a plastic welder, NOT a glue. Welding is the only way to repair some plastics. I have used industrial plastic welders in the past, and I'm certain the technology today is way improved since then.
You'd have to get the mating surfaces absolutely clean of any antifreeze, or whatever you use to fix the radiator will fail to hold.
Michelin Floatbib VF1000-55 R32 Equipment Tires (A64194)
Michelin Floatbib...
New/Unused Landhonor Quick Attach Pallet Forks (A65583)
New/Unused...
2022 KUBOTA KX057-5 EXCAVATOR (A65053)
2022 KUBOTA...
New/Unused Wolverine Quick Attach Tree Spade (A65583)
New/Unused...
2021 Caterpillar 259D3 Compact Track Loader Skid Steer (A64553)
2021 Caterpillar...
2008 Allmand Max-Lite ML20 20KW Towable Light Tower (A64194)
2008 Allmand...
