Radiator Leak
   / Radiator Leak #1
DannyV
Bronze Member
Santa fe, Texas
Yanmar YM2200
I have a very small leak in the bottom of my radiator. Its located somewhere behind the fins on my ym2200. Now I was wondering since its so small and I cant reach it with JB Weld has anyone ever used Prestone Leak-stop in their tractor? I thought about it but wanted to get some advice on the stuff.. /forums/images/graemlins/confused.gif
   / Radiator Leak #2
I have used a product for stopping leaks in tractor radiators. It is worth a try.
   / Radiator Leak #3
Dan,
I believe that Bars Leak is the answer. I used it in my International 444 approximately 15 years back an it is still holding. It only costs $3 or $4 at Wal Mart or any auto parts store. I have also used it in other vehicles with success.
Good luck.
   / Radiator Leak #4
I even used Bars Leak on a leaking freeze plug on a car and it stopped it. I have heard of it stopping leaks in a cracked block.
   / Radiator Leak #5
Before you just pour in a stop leak of some kind, I would wonder how large the passages are in the radiator. I learned the hard way on my Subaru. It had a small leak in the cooling system so just dumped in some stop leak. Couple months later a thousand mile from home car started over heating. Had to take it into a radiator shop and they pulled the top tank and found the passages which were small, almost completely stopped up from the stop leak.
Best do it right from the start, pull the radiator and fix the leak in a proper maner.
   / Radiator Leak #6
It should work fine as long as you are mindful of how much you use. I have a 15 oz. jug of Solder Seal super radiator sealer, (probably the same stuff), that says dump it in, however if your system is less than 9 quarts, only use half. I believe your system is only about 4-4 1/2qts., (1gal.+-), so I would only use about 4 ounces to prevent clogging.
   / Radiator Leak
Ok thanks for the replys..I will try it today and tell ya if it worked or not..
   / Radiator Leak #8
There was a time oatmeal was used!
Pull the rad and get it done properly.
Egon /forums/images/graemlins/grin.gif
   / Radiator Leak #9
Yeah, I remember that, and whole pepper, raw eggs, brown rice and a few others... /forums/images/graemlins/grin.gif
   / Radiator Leak
I put Bars Leak in the radiator and so far so good no leaks. I even had a small spot in my head gasket that leaked water down side of engine and it sealed that too. That bars leak is some good stuff if it doesnt mess up anything and I recommend it for this type of project... /forums/images/graemlins/grin.gif
2018 Toro Groundsmaster 7200 72in Zero Turn Mower (A48082)
2018 Toro...
2019 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2019 Ford F-450...
6 Trench attachment (A50322)
6 Trench...
2007 TROXELL KILL/TRANSPORT TRAILER (A50854)
2007 TROXELL...
Adams Conveyor (A51039)
Adams Conveyor...
JOHN DEERE 850J LGP DOZER (A50854)
JOHN DEERE 850J...
