Radiator Leak
   / Radiator Leak #1
SteveM
Upstate NY
Kubota B7100DT
A while back I posted some questions about the thermo-syphon cooling in my 78 Kubota, and now I know why I ran low on coolant - a pin hole leak in the top front of the radiator. I will have to remove the hood to see the leak, but once I get in there - is there a cement I can buy to repair the hole? I know I am not supposed to use the stop-leak goop....
Thanks in advance for your help!
   / Radiator Leak #2
You will have better luck with solder. the heat and pressure will make a " patch" hard to hold.
   / Radiator Leak #3
Have a radiator shop fix it right. It will be cheaper than a cracked head.
   / Radiator Leak #4
I had this problem recently. The radiator shop only charged $10 to solder it up.
Speaking of radiators and such, occasionally we will get a tractor in that has a lot of rust in the cooling system. There is a real heavy duty product that Prestone sells that cleans up the system like new. It is Oxcylic acid (sp?) in dry form, and the other side of the container has a neutralizer. You must follow the directions carefully as this is serious stuff, but you won't find a hint of rust when you are done. Not available at "fast food" type auto parts stores, I get mien at a local "All Pro" store.
JOHN DEERE XUV835M LOT NUMBER 25 (A53084)
JOHN DEERE XUV835M...
2019 FREIGHTLINER M2 26FT BOX TRUCK (A52577)
2019 FREIGHTLINER...
LINDE H70 FORKLIFT (A52472)
LINDE H70 FORKLIFT...
2015 Ottawa Yard Spotter Truck - Cummins Diesel, Allison 6-Speed, Hydraulic Air Fifth Wheel (A53472)
2015 Ottawa Yard...
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
