Radiator airflow
/ Radiator airflow
Does your AC condenser slide out? The AC condenser on my P7010C is on a track and the hoses have a loop in them. Remove 4 hand bolts to remove lower fairing then loosen 2 hand bolts to slide a plate over. Then unplug the pressure switch connector and the condenser slides all the way out. Can clean both sides and make it easier to get to radiator and oil cooler. No screen.
CT
No this is not possible on this model
2012 International (A59230)
2012 International...
2000 Thomas Built Saf-T-Liner Transit Passenger Bus (A59230)
2000 Thomas Built...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A61307)
2017 Yale GLC050VX...
2011 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A60736)
2011 DRAGON 150...
2021 Delta Manufacturing 30ft 10-Ton T/A Gooseneck Flatbed Equipment Trailer (A55851)
2021 Delta...
20FT X 30FT STEEL CARPORT (A58214)
20FT X 30FT STEEL...
