Radial tractor tires
   / Radial tractor tires #1
Mike rich
2650HD
Can you fill radial tractor tires?
   / Radial tractor tires #3
My owners manual shows how much to fill my radial tires with liquid. Just off of memory, I think it's 3/4 of the tire can be filled.
   / Radial tractor tires #5
Yes they can be filled but you may notice a stiffer ride since the fluid fill slows the tire flex some. Air compresses while water has to be moved to compress the air in the tire. Smaller air volume equals greater pressure change with tire movement.
   / Radial tractor tires #6
Most ag tire manufacturers do not recommend liquid ballast in radial tires. I have two tractors with radials and liquid ballast, and one tractor with radials and wheel weights. All other tractors have bias rears with liquid ballast. I do not like liquid ballast in rear radials, it negates some of the positives of radials and has a very bouncy ride on the road, I suppose due to softer sidewalls and liquid movement.
Swamp Buggy (A49346)
1956 641 Workmaster with PTO Tractor (A48837)
1956 641...
250ft Razor Wire (A48837)
250ft Razor Wire...
BUNDLE OF (5)12" X 14# MISC LENGTHS -7'6" - 9'3" (A50460)
BUNDLE OF (5)12" X...
2017 NISSAN NV200 VAN (A50459)
2017 NISSAN NV200...
2018 CATERPILLAR 299D2 XHP SKID STEER (A50458)
2018 CATERPILLAR...
