Snow Equipment Owning/Operating R4's and snow don't mix
   / R4's and snow don't mix #82
I've found the answer to this problem! when I get my 2nd and 3rd B7800 I'll get
one with R 1's and the 3rd one with Turf's :D
   / R4's and snow don't mix #84
I'm glad I've been through diversity training. :D:D:D
For those of you who don't know it's basically seeing the other persons point of view and keeping an open mind.
My self I have R1 (ag tires) and NO weight in the rear. I can use the loader as I'm heading down hill but not up hill. I can't use the blade what so ever.
Wedge
   / R4's and snow don't mix #85
Good Afternoon Guys,
OK lets throw a little twist in here ! :D
You only need 2WD and a good set of chains ! ;)
   / R4's and snow don't mix #86
How about 2wd and no chains. Worked for me for over 20 years, of course I had to be careful where I went. Much like drivers of 2wd pickups. You know the traction limitations and avoid areas that could pose problems. What I found interesting and sometimes frustrating, if clearing wet snow at near freezing temps., I had plenty of traction in the un-cleared deep snow. It was where I had cleared the snow away, the rear tires would spin because the lugs no longer got grip on the slick plowed surface. It needed the snow for traction!
No one has talked about possible effect of rubber compounds might have on winter traction, as in automobile snow tires. Maybe different tractor tire mfgrs use rubber compounds that grip better in the cold. Could have as much or more effect on traction on snow and ice than tread design. Also bias ply or radial might make a difference(?) All I know is traction on real REAL cold snow is never really a problem.
2015 Kia Sorento SUV (A50324)
2015 Kia Sorento...
2005 Club Car Cart (A55853)
2005 Club Car Cart...
Peterbilt Tandem Axle Road Tractor (A47477)
Peterbilt Tandem...
Kubota B2301 (A53317)
Booster Cables (A55852)
Booster Cables...
