Snow Equipment Owning/Operating R4's and snow don't mix
   / R4's and snow don't mix #21
I think it really matters on tire size, tractor weight, HP, snow type, ect, ect, ect. My 28Hp Jinma weighs 5,200# with me and the 7' rear blade on it. I have the R1's loaded with WW Fluid, rear weights, and front weights plus a FEL with a 5' bucket. Its a tank. I see alot of these 25ish HP tractors that weigh in at about 2,000#. They make good lawn mowers but not really cut out to do work like moving snow.
Chris
   / R4's and snow don't mix #22
For years I fought trying to push snow with my R-4's. They were useless in snow.
I added chains this year and the differance is AMAZING. Don't know why I waited so long before adding a set of chains.
   / R4's and snow don't mix #23
Since when is 10' in 100' considered a HILL ? Thats level ground around here. Our driveway has 3- 20/100 slopes. I normally wait until I get a good frozen base of packed snow/ice then put on the blower. I find that my R4s with chains are fine until I hit about 40'/100 (actually one spot on the maple syrup trail where I have to climb 4'/10' ) then I have trouble if the snow is deep or packed
   / R4's and snow don't mix #24
My r4s (loaded) were great for the first 2 winters i had the machine. by the 3rd winter, the leading edge of the treads were worn down somewhat and i think that they actually round-off. my driveway is 700'+ on a pretty steep hill. last year i added vbar chains on the rear only and now it is a tank. i can push and blow snow back up the hill now as well, so it cut my play time in half... i don't think any type of tire by itself will matter much on compacted, frozen snow/ice....
   / R4's and snow don't mix #25
I hear you! Our place is on the other side of Algonquin north of Dwight and we have some decent hills as I know you do in Bancroft. This is a view up the not-that-steep part of our drive, there are at least three spots significantly steeper.
As to more weight being better moving snow that may be a help when plowing but when you start to slide it isn't a help - in fact it makes things worse as asking more of the contact patch. Ask anyone who's slid off the road in a 7 ton loader...
With slippery conditions R4's on flat = ok, R4 on hill = bad, R4 + chains = :)
   / R4's and snow don't mix #27
Has anyone tried lowering their tire pressure to get a wider footprint. I do this with my R1's and it helps. Most of the R4's I see seem to have a lot of crown? to them.
Bill
   / R4's and snow don't mix #28
My Deere with 17.5x24 R4 tires in 4wd can't make it up a hill my truck can in 2wd:confused: It's time for some R1's or chains..
Interesting. My Kubota 7510 with R4 tires in 4wd easily drove up a wet, thick slush, snowy hill (my driveway) my 4x4 truck couldn't get up.
I think chains will do you more good, and be cheaper, than buying a set of R1's.
I want a set of front and rear lockers for my truck. :)
   / R4's and snow don't mix #29
Lockers on a truck are great. I ordered the limited slip on my 3/4 ton chevy. That plus the 500# of lead in the back that I cleaned out of the printing shop I run make my pickup a real monster, even in two wd. Lockers are even better. Again, I am a beliver in penetration, or high surface pressure for winter challenges. My narrow r1's that I should have at the beginning of next week will really increase the psi on the ground compaired to my wide turfs. We will see if it works as well as I hope. I just hate sliding sideways when using the rear blade angled.
Thanks for all the posts, some good info here. How about chevy,ford,dodge just kidding:D. Lungdoc I like your setup, r4's for all around use and chains for the winter months. I just ordered rear duo style chains but with 15 to 65 deg. paths I might still need to get the front set also. I have some 85 deg. quad paths here too but I try and keep the deere away from those ones:eek:
2004 Chevrolet Silverado 2500HD Service Truck (A53422)
2004 Chevrolet...
UNUSED WOLVERINE MAD-12-12D HYD AUGER DRIVE & BIT (A57193)
UNUSED WOLVERINE...
2014 Chevrolet Tahoe 4x4 SUV (A55853)
2014 Chevrolet...
CLAMP ON UNIVERSAL 42" FORKS (A54757)
CLAMP ON UNIVERSAL...
2021 Fleco DX140 24in Tooth Bucket Excavator Attachment (A55973)
2021 Fleco DX140...
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A55851)
Miller Trailblazer...
