r4047 - where is pto neutral switch/lever?
   / r4047 - where is pto neutral switch/lever? #11
It really shouldn't be that hard to turn the drive shaft on the implement to get it lined up with the PTO shaft. Just yesterday I had to rotate my tiller shaft to line up with the PTO and I just turned the shaft by hand, all I needed to do is lift the tiller slightly off of the ground so the tines were not hitting the floor and it is easy I have also done this on the brush hog many times except I do not need to lift it.
   / r4047 - where is pto neutral switch/lever? #12
On my new Yanmar Lx 490 you can, -- with engine running engage pto then turn off pto and it will spin freely. Engine was at idle.
2020 CATERPILLAR 289D3 SKID STEER (A60429)
2020 CATERPILLAR...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2016 FREIGHTLINER...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2016 Ford F-150...
2017 FORD F350 XL 35' NON-INSULATED BUCKET TRK (A59823)
2017 FORD F350 XL...
Massey Ferguson 4710 (A60462)
Massey Ferguson...
JCT 48" HYD TRENCHER (A52706)
JCT 48" HYD...
