R4047 Shuttle shift runs but won’t move!
   / R4047 Shuttle shift runs but won’t move! #1
Idfontenot
LS R4047
Anyone else had this issue? Loaders works, 3 point works, PTO works but I was doing next to nothing with it and it just stopped rolling. Doesn’t matter what gear the trans or the t case is in….just nothing. Can push it like it’s in neutral no matter in forward, reverse or neutral. Can shift shuttle without pressing the clutch and no grinding, still won’t move. I have a whopping 247 hours on it. Did my clutch just let go?
Thanks,
Dean
   / R4047 Shuttle shift runs but won’t move! #2
Did it stop all at once or have you noticed it slowing in higher gears?
Also, did you stop then it would not go again or were you in gear moving and it suddenly stopped?
Seem to have been normal/normal up until it stopped. I had been bush hogging and finished up so I could help move some bags of sand. Put 6 or 7 in the bucket, drove around the house and dumped it. Put it in reverse and the clutch released as normal then it just kind of glided to a stop. No noises, no drama.
   / R4047 Shuttle shift runs but won’t move! #4
Do you have free-play at the top of the clutch pedal?
   / R4047 Shuttle shift runs but won’t move! #5
Clutches normally don’t fail like that. It normally will start slipping in higher gears first. Sometimes an adjustment will help then but usually it is too late by then.
Did you try it with FWD engaged?
Got some free play at the top, tried it in every configuration there is. I’m befuddled.
   / R4047 Shuttle shift runs but won’t move! #7
Can you feel any resistance on the Shuttle lever? Or is it moving freely like it isn't connected to anything? I would check the linkages first.
   / R4047 Shuttle shift runs but won’t move! #8
Another vote for checking the linkages. My M4700 has "bound up" twice in the linkages during it's 10 years of very light usage.
The shuttle shift feels the same. Has the same notches for F/N/R as always.
2014 FORD F250 XL SUPER DUTY CREW CAB TRUCK (A51406)
2014 FORD F250 XL...
2016 Chrysler Town & Country Van (A51694)
2016 Chrysler Town...
KUBOTA M7-132 LOT IDENTIFIER 123 (A53084)
KUBOTA M7-132 LOT...
(INOP) FORD 7710 TRACTOR (A51247)
(INOP) FORD 7710...
JOHN DEERE CP 770 LOT IDENTIFIER 194 (A53084)
JOHN DEERE CP 770...
2019 Ford F550 Bucket Truck - Powerstroke Diesel - Auto Trans - 4X4 - 72258 miles -Altec AT40G Boom (A53473)
2019 Ford F550...
