R4047 Loader Zerk fittings? Can't find replacements...
   / R4047 Loader Zerk fittings? Can't find replacements... #1
RKJeepXJ
NC
LS R4047H
Anyone know what size and where to find a replacement zerk fitting for the pivot pins on the loader of my R4047?
They have hexagonal flanges like they are screw in but there doesn't seem to be threads in there so I'm thinking its a drive in still zerk. Are they screw in and this pin didn't get threaded at the factory? I'm missing 1 and if they are screw in I don't have a socket with a thin enough wall to take another one out to compare. If they are drive in I really don't want to try and pull one.
I can't find anywhere local (auto parts stores, tractor supply, etc) that have a drive in fitting that is large enough, everything is screw in.
   / R4047 Loader Zerk fittings? Can't find replacements... #2
Every zerk I have seen is threaded in. You may have to pull the pin and take it in to get the correct size if you can't get a sample out. B.
They do make press in zerks, they are pretty common on older equipment. I got this figured out so I'll post here for future reference for others.
The loader takes 8mm straight THREADED zerks. Mine was crossthreaded at the factory so the hole seemed to have no threads, they were stripped out. I ended up tapping and putting in a 1/8NPT threaded zerk to replace it since its a hair larger. Also, I checked the rest of the facotry ones and they were all a turn to 1.5 turns from being tight.
   / R4047 Loader Zerk fittings? Can't find replacements... #4
I had a simular issue and i too had spent over 2 hours and 30 bucks on every zerk fitting i could find and nothing worked with my LL5100 FEL mounted on the U5020c and ended up calling LS to get the exact part number.
40228707 - Nipple Grease Zerk , priced them out and they are around a $1.00 each depending on which dealer you go through of course
2017 Ford F-350 Crew Cab Pickup Truck (A55973)
2017 Ford F-350...
2007 FORD F-150 XL TRITON (A55745)
2007 FORD F-150 XL...
3410 (A47477)
3410 (A47477)
2015 Ford F550 Bucket Truck - Altec AT40M Boom - Powerstroke Diesel - Automatic Transmission - 4X4 (A55302)
2015 Ford F550...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A55315)
2012 UNVERFERTH...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A55315)
2016 RAM 5500...
